Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1993 Volvo 940 4 cyl Two Wheel Drive Automatic 220000 miles
I was driving and the dash lights came on. The car did not stop running but i didnt have any power when i pressed the accelerator. I pulled over and shut the car off, and when i tried to restart it wouldn't turn over. What are the possible problems?
Spray some carb cleaner into the throttle body and see what happens-if it starts and dies out-check the fuel pressure-up to specs, recheck ignition system by doing a spark test.
i have a 94 volvo 940 and about a year ago i had the same problem the car would just not go if you put the pedel to the floor would just eventually shut off. turned out to be a relay in the fuel pump.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
