Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Transmission problem
1993 Toyota Corolla 4 cyl Front Wheel Drive Automatic 190k miles
My car has a major transmission fluid leak. I have pinpointed the leak to the transmission fluid reservoir. I have the car on jacks and fluid is dripping from the reservoir on the inside part of the reservoir. How do I make repairs?
I am not sure what you mean by the transmission reservoir? are you referring to the transmission sump? if so, this is usually a case of removing the sump and replacing the gasket, this is an easy if messy job, just don't over tighten the gasket and don't use any sealant either. If you require any further information re post your question.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
