Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1993 Toyota Camry 4 cyl Two Wheel Drive Automatic
How do I locate and change a fuel filter on this vehicle
The fuel filter located under the air intake tube that carries the air to the throttle. Remove that black tube, only 3 screws/nuts and then u see the black filter there. Remove the nut that lies on top of the filter, then the one at the bottom. The bottom one is a bit hard to get to. Then remove the clamp that secures the filter to the car, again only 2 nuts/screws. Replace and reverse directions.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
