Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Automobile Safety Inspection
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair2006 Cadillac Cts Runni...
Auto Repair1999 Buick Regal Power ...
Auto Repair1993 Acura Integra Car ...
Auto Repair1998 Jaguar Xj8 Transmi...
Auto Repair1995 Pontiac Grand Prix ...
Auto Repair1999 Ford Taurus Squeak...
Auto Repair1986 Chevy El Camino Ta...
Auto Repair More Repair Topics...
We are the Car Repair Experts!
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1993 Pontiac Grand Am transmission wont shift
Posted at Sat Nov 07, 2009 7:36 pm
By johne317, Have Donated
Give Feedback | Votes: 0
Transmission problem
1993 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 312000 miles
I took my car in to the mechanic because the water pump blew and when i got it back, it wont shift. Mechanic replaced the water pump and serpentine belt, and car starts and runs great. I checked the TV cable and it was very worn, so i removed it and drove around to see if for some reason that was why but the problem remains. I have checked the linkage and it seems to be fine, car starts in park and neutral, reverse and drive engage and neutral is normal. Does not move in park so the transmission is shifting manually, but the thing wont go out of 1st! Fluid level is in operating range, actually a little over full... could that be the problem? I have been running it at the current fluid level for 12k miles so im just at a loss.
Find a car repair manual for your Pontiac Grand Am Repair Question.
Posted at Sat Nov 07, 2009 7:56 pm
By pear69, Moderator
(34) Give Feedback | Votes: 11
Did the mechanic test drive the car? If so, wouldn't of he or she detect this problem??
A worn out TV cable will not allow the transmission to properly operate --- driving around with it disconnected will damage the transmission..Try replacing the TV cable..
Posted at Sat Nov 07, 2009 8:32 pm
Yes, the mechanic test drove it, and yes he did identify the problem. The tv cable is necessary to have the transmission operate completely, however with the tv cable installed the transmission will not shift, and with it off it will not shift... so im not thinking the tv is the problem... I dont know if the transmission is vacuum controlled or electronic... it could be a couple of things i guess, i just dont know where to start.
Posted at Sat Nov 07, 2009 9:26 pm
Start by replacing the TV Cable. This cable tells the transmission and computer, how far the throttle body is opened. If it "very badly" worn, it will give false readings to the computer, which will in turn, not tell the transmission to up or down shift. Your transmission is electonicly shifted, but if you have a vacuum leak - it will affect the engine which will affect the transmission....
Posted at Fri Nov 13, 2009 7:55 pm
so i replaced the tv cable with a brand new one from GM and nothing... still the same problem. very frustrating.
Posted at Sat Nov 14, 2009 6:30 am
Assuming that the tv cable is adjusted properly -- When was the last time transmission fluid and filter was changed? Are there 312000 miles on this transmission? It should have been changed about 5 times so far. Did the transmission act like this before you took it to the mechanic for a water pump? Why is there too much fluid in the transmission?
Posted at Sat Nov 14, 2009 8:38 am
regarding the adjustment of the tv cable... there is a button type ... thing... on the cable. from what i understand i need to have the throttle all the way in the closed position and then press the button... but it doesnt seem to do anything. is there a different adjustment?
Posted at Sat Nov 14, 2009 5:57 pm
First, verify that it is hooked to the transmission properly. Then make sure that the throttle is at the idle position (closed). Then hook it up and push the button. It should only adjust about .07 of an inch -- not much..If the TV cable doesn't fix the problem, the control valve or something else inside of the tranny could be bad.
What about the other questions I asked?
If the reason that the tranny fluid is over filled is because that the fluid leaks (or at some point it leaked out), and the low fluid level was discovered too late, then you may want to consider rebuilding your tranny. Transmission fluid does not get consumed like engine oil, you should never have to add any.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
