1993 Plymouth Acclaim DTC 37
MYSTICSTYLES352
  • 1993 PLYMOUTH ACCLAIM
  • 4 CYL
  • 200,000 MILES
I have a 1993 Plymouth Acclaim 2.5l base. It cranks everytime but is having difficulty starting everytime. It`s throwing code 37, part throttle lock/unlock solenoid driver circuit. I`m not sure if this is referering to the TCC solenoid or not. Any help on a fix would be appreciated.
Tuesday, December 22nd, 2009 AT 12:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC 37 : Torque Converter Clutch (TCC) Solenoid Circuit
Suspect faulty TCC solenoid or bad wiring to the solenoid. If both are OK then replacement of the PCM may be required.
Tuesday, December 22nd, 2009 AT 12:47 PM
