Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Shakes or Wobbles problem
1993 Other Plymouth Models 6 cyl Front Wheel Drive Automatic 139000 miles
whenever i open my windows, they kinda chug down. i dont know whats wrong with them
It sounds like the internal gears need lubericated. It will require you to remove the door panel. Once you do that, you should be able to see the gears / linkage. Use an all purpose grease and place a thin film over all of the geared linkages.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
