Posted at Mon May 05, 2008 11:49 am |
By
buster11,
Have Donated |
Give Feedback | Votes: 0 |
Brakes problem
1993 Mazda 626 4 cyl Front Wheel Drive Manual 222kms miles
The ex had the front pads and calipers replaced on her car , now the pedal is up at the top and hard and sensitive and the brakes are sticking ( you can smell them and feel the vehicle slowing down ) , could it be the power brake booster gone bad , or the proportioning valve need resetting . There is no leakage . I did notice previously ( before the brakes were done ) that the idle was affected more than usual when braking . Any help appreciated .
| Find a
repair manual for your Mazda 626 Repair Question. |
By
Advertisment,
| Find a
Posted at Mon May 05, 2008 11:59 am |
By
buster11,
Have Donated |
So the symptoms would not point to a faulty master cylinder , correct ?
| Find a
Posted at Mon May 05, 2008 12:16 pm |
By
buster11,
Have Donated |
So why would the brakes be dragging ?
| rasmataz wrote: | | So the symptoms would not point to a faulty master cylinder , correct if there's a problem with MC your foot will be sinking to the floor- |
| Find a
Posted at Thu May 08, 2008 3:25 am |
By
buster11,
Have Donated |
The pedal was not like this before the calipers were changed , when I checked the fluid the smal plastic cap that just sits under the screw on cap was very tight to come out (has a rubber O-ring on it) , I did the quick checks on the booster and check valve that you mentioned and they seem OK . She took the car in for a free inpection at Speedy and they told her that the brake fluid was contaminated with another type of fluid causing all the seals to swell and thus the calipers to stick (thus the hard to remove dust /dirt cap as mentioned previously) . I have not seen brakes with improper fluid in them before but it sounds like someone really screwed up if that is the case . You guys are the pros what is your take on this idea ? Thanks
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
