Engine Performance problem
1993 Mazda 626 4 cyl Front Wheel Drive Manual 125000 miles
Car is idling low , base idle was reset at dealer about a year ago due to same problem , 5 min and 95 bucks , I read somewhere but can't remember where that it can be reset through the DLC by grounding a pin , if so which pin and where is the dlc on this car . Any help appreciated
Find a
repair manual for your Mazda 626 Repair Question.
To: rasmataz
Posted: Tue Mar 25, 2008 8:20 am
Subject: 1993 Mazda 626 DLC / pin 10
Is the DLC under the dash or hood , are the pins numbered for easy ID or do you have a pic . Thanks
Its under the hood next to the power distribution box-it will show the pins under the cover
Find a
Posted at Tue Mar 25, 2008 1:02 pm
By
merlin2021,Certified 2CarPros Master Technician
The Mitchell1 procedure you sent in your response for relearn drive is cut off for the manual transmission after the first line , can you include it please , also is the pin 10 grounding procedure done key on engine off .
rasmataz wrote:
The DLC is on the drivers side near the power distribution box-jumper TEN and GND then adjust it see below-also do the computer relearn
Find a
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins.Click
here to find out more.
