Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1990 Other Nissan Models
Auto Repair2001 Toyota Corolla "ra...
Auto Repair2001 Nissan Sentra Mult...
Auto Repair2003 Ford F150 Leaf Spr...
Auto Repair2005 Ford Expedition Wh...
Auto Repair2001 Hyundai Elantra En...
Auto Repair1999 Ford Taurus Lighting
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Lincoln Continental Air ride compressor starts running
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Sep 22, 2008 4:39 pm
By pjwolf, Have Donated
Give Feedback | Votes: 0
Suspension problem
1993 Lincoln Continental 6 cyl Front Wheel Drive Automatic 135000 miles
When I shutdown the engine and get out of the car, I can hear air releasing from the air struts as the car levels. However, after about 30 seconds, the air suspension compressor starts running and won't shut off unitl the front end of the car is raised way up and the front struts are solid. When I get in the car and start driving around, it only takes a few blocks and the vehicle is leveled out normally. But I stop, shut off the engine, get out of the car and about 30 seconds later the compressor starts running and won't quit unilt the front is way jacked up. If I turn off the air ride switch in the trunk, of course, the compressor stops. I can immediately turn the switch back on and the compressor will not run. I replaced the actuators on the front struts but that didn't seem to help. I've had it into a dealershp and they are baffled. They said I might neet new front level sensors but they weren't sure. But that doesn't make sense to me. If the level sensors were not working, it wouldn't level out and ride normally when the vehicle is running, either. This only happens after I shut off the engine, get out of the vehicle and shut the doors.
Find a car repair manual for your Lincoln Continental Repair Question.
Posted at Thu Sep 25, 2008 5:06 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7Reputation: 683.7 (684) Give Feedback | Votes: 80
That is a good one. with key off sounds like the controller is losing power or something to cause it to get possible false readings from the front sensors.They should have the ability to watch it with a scan tool to see what itis doing
Posted at Mon Sep 29, 2008 6:57 am
I have been struggling with this issue for a year now. I have had the car in to a dealer. They hooked up scanners and couldn't find anything wrong. I also asked a lot of questions but no one seems to be able to figure out this problem. In the mean time, every time I get out of the car I have to open the trunk and shut off the air ride switch then turn it back on when I am going someplace. So I installed a solution that cost $4. Pin number one of the wiring array going into the air ride control module is hot when the ignition is on and off when the ignition is off. Using that to trigger a $4 relay switch, I spliced into one of the wires going to the shut off switch. Now when the ignition is on, the current going to the switch is connected and the system is on. When I turn off the ignition, the relay switch is open and the air ride system is shut off just like I had manually turned the switch off and the compressor doesn't run.
Posted at Mon Sep 29, 2008 7:00 am
That is an above average fix to an above average problem. Have you tried unplugging the ride sensors on the front or rear to see if it makes a difference?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
