Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1993 Lexus LS 400 V8 Two Wheel Drive Automatic 172,00 miles
Engine will crank and run for about 1 second then quits.
I pulled OBD code and came up with a "15". The only info I have found on this code is "Ignition Number 2". Does this point to an Ignition control module problem. Thank you for any info.
I went to that site, on your recommendation, using the link, you provided. It is a working site but does not allow one to purchase a manual. You might want to check it out, since it is faulty.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
