Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1993 Jeep Cherokee Jeep wont start
Posted at Thu Nov 19, 2009 2:19 pm |
By
charettem,
Have Donated |
Give Feedback | Votes: 0 |
Engine Mechanical problem
1993 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 140000 miles
I have a Jeep Grand Cherokee Limited 1993, with 140k, the jeep had sat for about a year and a half with about 1/8 tank of gas in it, the fuel filter that it came with was pretty clogged to the point that eventually it caused my jeep to not start, I went ahead and replaced it, it started right up and ran great! I parked it, and now it wont start again, I figured maybe this filter clogged up too so I changed it, but when I cut into it it was clean, and the jeep will not start with the new filter either. There is fuel going to the engine and the pressure is perfect. What could be wrong? |
Find a
car repair manual for your Jeep Cherokee Repair Question.
Posted at Thu Nov 19, 2009 2:30 pm |
By
rasmataz,
Certified 2CarPros Master Technician |
                            (14666) Give Feedback | Votes: 347 |
There is fuel going to the engine and the pressure is perfect. What could be wrong? Could be no spark check it |
Find a
Posted at Thu Nov 19, 2009 2:33 pm |
By
charettem,
Have Donated |
Would it just stop sparking all of a sudden though? the thing was running great and then just died out, another note, the tach is reading 1.5-3 when I turn the key on, it slowly "idles down" back to 0 when I crank it over. I will check for spark though, thanks for the fast reply! |
Find a
Posted at Fri Nov 20, 2009 4:03 pm |
By
KHLow2008,
Certified 2CarPros Technician |
         (5111) Give Feedback | Votes: 68 |
When he tachometer acts funny, it indicates a fault with the sparks ignition system and most probably the ignition coil and/or related parts have failed.
When this happens, it would stop sparking suddenly. |
Find a
Posted at Sat Nov 21, 2009 10:51 am |
By
charettem,
Have Donated |
| KHLow2008 wrote: | When he tachometer acts funny, it indicates a fault with the sparks ignition system and most probably the ignition coil and/or related parts have failed.
Okay, thank you, I am going to swap out the coil with one I have from another jeep 4.0, if it starts right up I will go ahead and order a new one. Thank you very very much. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
