Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2003 Toyota Camry Serpe...
Auto Repair2000 Ford Contour Alter...
Auto Repair1998 Mazda Mx5
Auto Repair1991 Ford Festiva Dippe...
Auto Repair1995 Nissan Truck How T...
Auto Repair2000 Dodge Caravan Stee...
Auto Repair1999 Other Saturn Models...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Jeep Cherokee fuel pump
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Jun 26, 2008 7:28 am
By Jvansant, Have Donated
Give Feedback | Votes: 0
Electrical problem
1993 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 104000 miles
I have a 1993 Jeep Cherokee. Was driving it and it quit running. Had it towed. Key on sends 12V to the fuel pump for just a brief second, but does not energize fuel pump. Of course, I replaced pump and filter. Still no fuel pump engagement. The fuel pump will run if I put 12 V to it, but I am not able to get it to prime and send fuel to the rail, tank is about 1/4 full. Back to the real problem. I do not have 12V to the fuel pump except for a few milliseconds. I have checked ALL the fuses (3 times, because sometimes I am stupid), I have replaced the fuel pump relay. The fuel pump relay has always made an audible click indicating mechanical function. I pulled the PCM,ECM or whet ever it is defined as on this particular vehicle. There was some pretty visible corrosion on, maybe 2 or 3 pins, cleaned this up w/dental picks, elect parts cleaner and compressed air. Still no fuel pump. I would literally have to tear this car apart to trace the wire from the fuel pump to the power center. I have a Haynes manual which is for all intents and purposes useless in this instance. If I had a good wiring diagram or just the info to pin it out I might be able to figure it out. I found a Jeep 1993-94 2.5 and 4.0L EFI powertrain Diagnostics factory service manual. Would this manual provide the info. I need to further diagnose this vehicle? Any help would be gratly appreciated. Thanks, John V.
Find diagnostic tools, replacement parts or locate a car repair manual for your Jeep Cherokee Repair Question.
By Advertisment,
Posted at Fri Jun 27, 2008 4:40 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5Reputation: 639.5 (640) Give Feedback | Votes: 80
Try swapping the ASD (auto shutdown relay) with another one (a/c) and see if that will work. If the PCM doesnt power up, the rest of the system wont work properly
Posted at Sat Jun 28, 2008 2:27 pm
Just to keep everybody posted. The brand new Airtex fuel pump assembly was bad and that's why I couldn't get it to pump/prime. Installed a new pump assy, but of course still no power to the pump, except for just a brief second when the ignition key is first turned on. Vehicle runs perfectly when I hot wire the fuel pump. Anyone have any suggestions? John V.
Posted at Sat Jun 28, 2008 2:31 pm
Oh, replacing both the ASD and fuel pump relays was the very first thing that had I tried. John V.
Posted at Sun Jun 29, 2008 5:06 am
John, I need to know exactly which Cherokkee you have. There are 7 different versions
Posted at Tue Jul 08, 2008 7:23 pm
I finally resolved the fuel pump problem on this Jeep Cherokee. It is a 1993 Cherokee Sport 2 door. It has a 4.0 litre 6cyl., auto, air , 4wd. I purchased the factory service manual, I traced the fuel pump circuit and discovered that I was losing power at the "fuel pump ballast resistor" It is my understanding that this is put in the circuit to reduce fuel pump voltage and thereby noise, under normal driving conditions but is bypassed by the ECM and a "bypass relay" under WOT conditions. The service manual did not give a spec for this resistor but it ohmed out at 78ohms. Seemed kind of high to me. Tried to find the part, but nobody (not even the dealer)knew what I was talking about. I bypassed it, everything worked great. Finally found the part and, new, it had exactly 1.1ohms of resistance. Replaced the bad resistor now everything is peachy. John V.
Posted at Thu Jul 17, 2008 12:45 pm
By fuzga2, New to the forum
John,
I too have the 1993 Jeep Cherokee Sport, 4dr, 4.0L and 6cy. Our problem is very similar I repalced the fuel pump and the fuel filter. Just can't get the fuel going into the line, the fuel is running and measured at the connector to the fuel pump, I am getting only 6.832 VDC. Tried the bypass on the resistor, still won't work and the ballast resistor measured at 1.5 ohms.
With all the experiences that you had on this problem, may be you can shine some light to this ...
Dennis
Posted at Fri Jul 25, 2008 7:45 pm
Well Dennis, you need to figure out where you have 12v. in the fuel pump circuit, then where you're losing it. 12v. should be going to the fuel pump for 1 sec. when the ignition is turned on or constantly when the starter is turning the engine over or when the engine is running. I would confirm that the fuel pump is working by VERY CAREFULLY jumping 12v. directly to the fuel pump to see if it pumps fuel and runs (make sure that you have correct polarity). If that works get a 12v.(dc) buzzer or light then see if or when you actually get 12v back to the fuel pump. If you don't want to trace the circuit and just punt, I would clean every ground and plug connector in the F.P. circuit, I would check and clean the big ECM connector, I would replace the fuel pump relay and I would eliminate the ballast resistor . If you truly have a 1993 I could probably help you out w/a factory wiring diagram (if your patient). Good Luck. JohnV
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
