Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Dodge Stratus Clue...
Auto Repair1993 Honda Civic Distri...
Auto Repair1996 Dodge Stratus 1996...
Auto Repair1968 Ford Mustang Heate...
Auto Repair1989 Holden Commodore
Auto Repair1999 Honda Civic Altern...
Auto Repair1990 Ford Bronco Rear W...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Jeep Cherokee Approximate cost to replace a fuel pump
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Oct 13, 2008 6:12 am
By Colin_Schroeder, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1993 Jeep Cherokee 6 cyl Four Wheel Drive Automatic 170000 miles
I am trying to find out how much it should cost for me to replace the fuel pump. The car is hesitant to start right now and I will need to get it fixed before winter.
Find a car repair manual for your Jeep Cherokee Repair Question.
Posted at Mon Oct 13, 2008 10:36 am
By jnovack, Moderator
Reputation: 97.2Reputation: 97.2Reputation: 97.2Reputation: 97.2Reputation: 97.2 (97) Give Feedback | Votes: 3
You should be able to do this yourself here's how.
Removal & Installation
Disconnect the negative battery cable.
Remove the fuel tank filler cap.
Using a siphon hose, drain the fuel tank below 1/4 full.
Block the front wheels and raise and support the rear of the vehicle with jackstands.
Remove the fuel inlet and outlet hoses from the sending unit Be ready to catch any spilled fuel.
Remove the sending unit wires.
Using a brass punch and hammer, remove the sending unit retaining lockring by tapping it counterclockwise.
Remove the sending unit, which incorporates the electric fuel pump, along with the O-ring seal from the fuel tank. Discard the O-ring.
Remove and discard the pump inlet filter.
Disconnect the fuel pump terminal wires.
Remove the pump outlet hose and clamp.
Remove the pump top mounting bracket nut and remove the pump.
To install:
Install a new inlet filter on the pump.
Assemble the pump and bracket. Connect the hose and wiring.
Install the unit and new O-ring in the tank. The rubber stopper on the end of the fuel return tube must be inserted into the cup in the fuel tank reservoir.
Install the lockring. Carefully tap it into place until it seats against the stop on the tank.
Connect the hoses.
Connect the wiring.
Lower the truck, fill the tank, run the engine and check for leaks.
TESTING
Remove the plug from the test port and engage a test port fitting in its place.
Connect a fuel pressure gauge to the test port fitting.
Start the engine and let it idle.
The pressure gauge should read 14-15 psi (97-103 kPa).
If the pressure is correct the fuel pump is operating normally.
If the pressure is not correct, adjust the fuel pressure regulator to obtain the correct pressure by turning the screw at the bottom of the regulator inward to increase pressure or outward to decrease pressure.
If the fuel pressure is considerably above specification and adjusting fails to lower it within specification, inspect the return line for an obstruction.
If the fuel pressure is considerably below specification and adjusting fails to raise it within specification, momentarily pinch off the return line and recheck the pressure. If pressure has risen, replace the regulator. If it has not, check the filter and supply line for an obstruction.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
