Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2008 Bmw 318 No Heating...
Auto Repair2001 Chevy Blazer Need ...
Auto Repair2006 Toyota Corolla
Auto Repair2004 Ford Explorer Tie Rod
Auto Repair2007 Dodge Charger Tach...
Auto Repair2003 Bmw 325 Blower Stops
Auto Repair1998 Chevy Cavalier Tra...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Honda Accord
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Sat Sep 06, 2008 7:55 pm
By stephanie123, Likes cars!
Give Feedback | Votes: 0
1993 Honda Accord
I tried to use the staring fluid to get my car started but it still will not start. any sugestions??
Find a car repair manual for your Honda Accord Repair Question.
Posted at Sat Sep 06, 2008 8:06 pm
By obxautomedic, Moderator
Reputation: 57.4Reputation: 57.4Reputation: 57.4 (57) Give Feedback | Votes: 6
stephanie123 wrote:
1993 Honda Accord
Check for spark at the Cap if have spark at cap check spark at plugs. If no spark at plugs replace cap and rotor.
If no spark at coil check power to coil if have power replace coil.
Posted at Sun Sep 07, 2008 4:27 pm
I have new spark plugs, spark plug wires and coil wire, distributor cap and roter.
But what started it all is that I was driving my car and it shut off like I just turned the car off and I looked unre the hood and the spark plug chambers were full of oil. So I change the Vaulve gasket, and the rest that is stated above. I tried the starting spray and it is trying to start but will not completely kick over. I even have a brand new battery in the car that is only about weeks old. I am stumped about what may the problem be. I need help.
Posted at Mon Sep 08, 2008 5:36 am
Ok, you say you changed the Coil Wire.... Have you checked for Spark at the Plugs? When checking look at spark closely the color should be a Bluish/White if it is an Orangish color the Spark is not strong enough to start vehicle.
Posted at Mon Sep 08, 2008 7:42 am
Before I changed the coil wire it had a spark that was orange that is why I had changed it. And i did check the spark plugs spark and there was not one. what do i do from there? what is the problem?
Posted at Mon Sep 08, 2008 10:56 am
By KHLow2008, Moderator
Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7 (175) Give Feedback | Votes: 12
Hi stephanie123,
Orange spark means the sparks are weak and you need to replace the ignition coil.
Posted at Wed Sep 10, 2008 8:20 am
I changed the ingntion coil and it still not start. what else can there be???
Posted at Wed Sep 10, 2008 11:09 am
Hi stephanie123,
Lets start all over again.
1. Check for sparks at spark plug.
2. Check fuel pressure at fuel rails. ( Try starting fluid again )
3. Test compression.
Posted at Mon Sep 15, 2008 7:03 am
there is not a spark in the spark plugs, starting fluid did not work. The roter turns slow when I am trying to start the car.
Posted at Tue Sep 16, 2008 3:21 am
Hi stephanie123,
Ok, we need to find the cause why there is no spark with all those new things.
1. Check for power supply to the distributor Black/Yellow wire with ignition on.
2. Remove distributor cap and crank engine, is the rotor turning? Make sure distributor cap is away from rotor.
If yes to the above, check the ignition coil and ICM for proper connection of the wires. If all are ok, the ICM is faulty.
Make sure cranking speed is sufficiently fast, use jumper battery if necessary.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
