1993 Honda Accord Removing Water pump
CAT95204
  • 1993 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 220,000 MILES
Trying to remove the water pump on my 93 Honda Accord and am having trouble removing the crank bolt.
Is it a reverse thread? Is there a special tool I need to get it off? It just won't turn.
Friday, July 4th, 2008 AT 8:09 PM
KHLOW2008
  • 41,815 POSTS
Hi cat95204,
The bolt is torqued at 150 ft/lbs, normal thread.
Either you have a high torque impact wrench or you need a special tool to hold the pulley.
Make sure you get the timing belts markings correct before removing them. The balancer shaft belt can cause a lot of problem if not correctly installed.
Saturday, July 5th, 2008 AT 7:59 AM
