Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2005 Nissan Sentra Car ...
Auto Repair1995 Geo Prizm Little T...
Auto Repair1992 Oldsmobile 98 Oil ...
Auto Repair1993 Other Buick Models ...
Auto Repair2003 Mitsubishi Galant ...
Auto Repair1996 Chevy Suburban
Auto Repair2008 Dodge Stratus Dist...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Geo Storm rough idle
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Mon Apr 21, 2008 12:46 pm
By ddgirl1980, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1993 Geo Storm 4 cyl Two Wheel Drive Automatic 145000 miles
i have recently had the spark plugs, and wires, and distributor cap replaced also the throttle body has been recently cleaned out yet the car still idles roughly but only when the engine is warm what could be the problem?
Find a car repair manual for your Geo Storm Repair Question.
Posted at Fri Sep 19, 2008 6:22 am
By justaluckyshot, Likes cars!
Ah, Yes, My 90 Geo Storm 2+2 does PRECISELY the same thing.
Ive had expert mechanics look at it, and everyones baffled.
First off, we pulled the valve cover, set the valve clearance, checked for stuck valves. nothing. clean as a whistle.
Then we tested the TPS, works to a T.
Then we swapped O2 Sensors, which helped, but didnt solve my problem.
We then adjusted Ignition timing, which also helped.
What i suggest doing, swap a new Idle Air Control valve in there, AND, flush the motor, i suggest seafoam.
THEN, clean the injectors. Even if it doesnt fix this problem, it will always help. =D
Hope i helped
Posted at Mon Sep 22, 2008 11:38 am
Hope i helped
just got it outta the shop again. the IAC didnt help. the timing is still right, yet it still has this problem.
ign timing seems to up itself when the AC is on, and it makes the idle smooth out. but when we advance the ign timing to where the AC knocks it up to, its no better.
Somewhere along the line, something engages with the AC button, along with the IAC racing, and the timing upping. whatever THAT thing is. ITS the problem.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
