Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1995 Geo Prizm How To R...
Auto Repair1991 Honda Accord Sudde...
Auto Repair1999 Subaru Outback Clutch
Auto Repair1992 Oldsmobile 98 Oil ...
Auto Repair1993 Chevy Suburban 4 H...
Auto Repair2000 Toyota Sienna Orga...
Auto Repair1987 Chevy S-10 Weird N...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Ford Probe INSTRUMENT CLUSTER
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Thu Aug 21, 2008 8:48 am
By JIMTL, Likes cars!
Give Feedback | Votes: 0
Electrical problem
1993 Ford Probe 4 cyl Front Wheel Drive 120000 miles
1993 PR0BE 2.OL DOHC . IWAS CHECKING TROUBLE CODES WITH JUMPER WIRE .IMADE A MISTAKE AND JUMPERED GROUND TO +B TERMINAL . NOW WHEN I TURN KEY ON THE CHECK ENGINE LIGHT AND CLUSTER LIGHTS WILL NOT COME ON .WHAT DID I SHORT OUT AND HOW DO I REPAIR . IS.THERE AFUSE TO CHANGE OR LIGHT BULBS TO CHANGE ON INSTRUMENT CLUSTER.
Find a car repair manual for your Ford Probe Repair Question.
Posted at Thu Aug 21, 2008 9:10 am
By blackop555, Certified 2CarPros Master Technician
Reputation: 106.8Reputation: 106.8Reputation: 106.8Reputation: 106.8Reputation: 106.8 (107) Give Feedback | Votes: 27
sound slike you possibly blew a fuse or burned some bulbs, check in your fuseblock for all uses, ground a test light and use the tip to check each side of each fuse while plugged into the fuse block, there is a metal tab at each side at the top that you can touch it on.
when you find one that has power on one side, none on the other with the key on of course, then you have found the bad fuse.
after you look at the fuses, you will have to remove the instrument cluster and check the bulbs on the back of it if they are burned they will be black in color not clear.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
