Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2001 Dodge Dakota Automa...
Auto Repair2002 Daewoo Leganza Starter
Auto Repair2007 Alfa Romeo Spider
Auto Repair2003 Volkswagen Jetta Br...
Auto Repair1995 Isuzu Trooper Slow ...
Auto Repair1969 Chevy Corvette Brakes
Auto Repair2001 Oldsmobile Bravada ...
Auto Repair2005 Toyota Corolla Sque...
Auto Repair1999 Honda Prelude Shift...
Auto Repair2003 Ford Explorer Anti ...
Auto Repair1989 Chevy Celebrity Rece...
Auto Repair2001 Dodge Ram Sensor Lo...
Auto Repair2004 Chevy Cavalier 2004...
Auto Repair1990 Ford Aerostar Runs ...
Auto Repair2004 Chevy Silverado Spe...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Ford Bronco hesitates and sputters at highway speeds
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Sat May 17, 2008 8:49 am
By mccullek, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1993 Ford Bronco V8 Four Wheel Drive Automatic 125000 miles
This is a well maintained Bronco and I recently had the transmission rebuilt, and the motor tuned up. We replaced all of the spark plug wires and plugs, etc. I also had the radiator flushed out and installed a new thermostat.
The engine cranks and runs great, even when it has been sitting for a month or longer. Around town, it runs great, although the temperature sensor seems to run hotter than normal, the engine never over heats. I took it to a radiator shop and they said to put an original thermostat part in it and I did that, but it still seems to run at a higher temperature and occasionally moves over to the over heat area, and it does seem to be running hotter, but the engine doesn't really over heat? Around town it runs great with lots of take off power and it cranks and idles well.
However, when you take it out on the highway, once you get up to around 50-55 miles an hour, it starts sputtering and hesitating. If you accellerate, it will kick out of over drive and take off with lots of power, but as soon as it goes back in OD, it starts sputtering and hesitating again.
I'm not sure if the temperature issue is related to the highway hesitation and sputtering, but I would like to solve both issues even if not.
Find a repair manual for your Ford Bronco Repair Question.
By Advertisment,
Posted at Sat May 17, 2008 10:41 am
By mastertechtim, Tech level 9
Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2 (245) Give Feedback | Votes: 16
unplug the egr valve and see if the problem goes away, if not i think your going to find a bad spark plug and or plug wire.
Posted at Sat May 17, 2008 6:48 pm
OK, I unplugged the electrical connector that goes into the EGR, I assume that is what you are referring to when you say unplug it? This did help considerably, but it did not cure the problem in full. I still get some hesitation when you start up an incline or steeper hill while at higher speeds. The check engine light is on as well, but I'm sure that is to be expected with the EGR being unplugged.
Will it hurt anything to run the engine with the EGR disconnected, or do I need to replace it and plug it back up? I prefer to just leave it off if it doesn't damage the motor in any way.
One other item, I read somewhere that there is a problem with Ford 5.0 V8 motors in my year range in which the 8th cylinder doesn't fire correctly due to the PCV valve being in the rear of the motor and that it needs to be moved to cure this problem. Could this have anything to do with my issue?
Thanks for your help so far.
Posted at Sun May 18, 2008 7:35 am
i have never heard of the moving of the pcv valve but you can leave the egr disconnected. also unplug the vacuum line to it and plug it, this should make a real big difference
Posted at Mon May 19, 2008 4:27 pm
Is there a trick to fooling the check engine light so that it works but ingores the ERG issue?
Posted at Tue May 20, 2008 8:10 am
not that im aware of.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
