Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1993 Ford Aerostar 6 cyl Two Wheel Drive Automatic 180000 miles
93' Aerostar, 3.0 V6 180K miles
Dash lights and Radio lighting goes out when Headlights are turned on. Also intermittent tail lights working.
Replaced Dash Cluster On/off switch. Replaced wiring block that attaches to switch. Brown wire from harness is a bit frazzled and wiring block melted around Brown connector. Lights may return briefly with a bump in the road but then go out again. Any suggestions?
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
