Auto Repair Chat - Ask a Question, Get a Free Answer
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1993 Dodge Shadow Brake lights
Posted at Sat May 23, 2009 1:26 pm |
By
muffinattack,
New to the forum |
Give Feedback | Votes: 0 |
Electrical problem
1993 Dodge Shadow 4 cyl Two Wheel Drive Automatic 153000 miles
Well my driver side tail light works, UNTILL I hit the break then it goes out. The driver side turn singal also does not work. I checked the fuse, I replaced all the bulbs. when I turn the driver side turn signal on the light stays solid. I'm baffled and I was just seeing if this was something I could maybe fix before taking it in, because I got the car for 250$ 3 years ago and shes still going strong. And to be honest there ar eso many things wrong with it dumping to much money into it would be a waste. any suggestions would be nice, thanks guys. |
Find a
car repair manual for your Dodge Shadow Repair Question.
Posted at Fri Jun 05, 2009 11:16 am |
By
caradiodoc,
Problem solver! |
    (489) Give Feedback | Votes: 8 |
That's the classic description of a bad ground on any car that shares the brake / signal filament and tail light filament in the same bulb.
Your car has unusual rear sockets that have plug-in ground terminals. They get corrosion buildup or the terminal corrodes off. You will see that the left brake light is not as bright as the right one. Current must go through the brake light, tail light, and over to the right tail light to get to ground. That's like three people standing on your garden hose instead of just one. Current goes down in the hose and in your brake light.
The dealer has repair terminals, but it can be hard to get inside the opening to shine up the contact. You might be better off just buying a new socket, or see if you can find a place to solder on a new ground wire. Do not use Scotch-Lok connectors for your new socket. The only professional repair in a high-moisture environment is to solder splices and cover them with heat shrink tubing.
caradiodoc |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
