Free Auto Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1993 Chrysler Imperial Serpentine belt
Posted at Tue Oct 13, 2009 4:30 am |
By
Quagmire86,
Has a wrench in each hand! |
(26) Give Feedback | Votes: 2 |
Engine Mechanical problem
1993 Chrysler Imperial 6 cyl Front Wheel Drive Automatic 155000 miles
I have an issue with my serpentine belt that only happens when the roads are wet. The serpentine belt will come off the pulleys. I've checked the alignment (by eye) and it all seems kosher. I even put a new tensioner and belt on (hours of fun). There is no issue when the roads are dry, but as soon as it is wet, it will religiously throw the belt off. I was told that it is a frequent problem with these cars. Something about the splash guard on the lower right front hitting the belt run. But I can't see the problem there since every time the belt comes off, the only way to get the thing on again is to remove the wheel & spash guard to gain access to it. There is only one way for the guard to affix to the frame. I am thinking about replacing the "Idler" pulley but I hate to throw money at a problem and not know if that is the issue. |
Find a
car repair manual for your Chrysler Imperial Repair Question.
Posted at Tue Oct 13, 2009 12:04 pm |
By
Docfixit,
Certified 2CarPros Master Technician |
         (4955) Give Feedback | Votes: 81 |
3.8L ? is belt routed as in diagram?
Find a
Posted at Fri Oct 16, 2009 10:04 pm |
By
Quagmire86,
Yep, That is how I repeatedly have been routing it. It is solid when dry, but when the roads are wet, the belt is guaranteed to fall off. I can't tell you which pulley the belt is slipping off from. When I put the belt on and run the engine, I do not see any "Wobble" from any of the pulleys. There is no squeeling or sign of binding when it is running (while it is dry). All the pulley mounts are tightly affixed to their brackets. |
Find a
Posted at Sat Oct 17, 2009 6:57 am |
By
Docfixit,
Maybe worn pully on water pump assume it's real shinny and slick. You said water shield in place so that's out. Try this engine running spray water at crank see what happens. |
Find a
Posted at Sat Oct 17, 2009 6:26 pm |
By
Quagmire86,
That's a good idea. I will give that a shot. The water pump pulley doesn't look too shiny but the idler pulley is very shiny. Thanks for your help. |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
