Auto Repair Talk - Ask a Question, Get a FREE Answer.
Go Back
1993 Chevy Truck Engine backfires and has no power at drive
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Tue Apr 29, 2008 3:50 pm |
By
Welkmeister,
Have Donated |
Give Feedback | Votes: 0 |
Engine Performance problem
1993 Chevy Truck 6 cyl Four Wheel Drive Automatic 140000 miles
My truck has a Z-code 4.3L V-6, no emission air pump, A/C, TBI, all stock. It starts and idles fine but when I'm on the road at 55-60 mph and try to accelerate it has a very noticeable hesitation and occasionally backfires. Took it to the local Chevy dealer and they said it was the EGR valve so they replaced it. It still does the same thing. Did the normal routine...new plugs, wires, checked distributor and rotor (both look fine), new air filter, cleaned the injector fuel screens, new fuel filter, verified correct timing, nothing seems to help. No codes on the ECM so I'm totally lost. I have an Actron code scanner and I did the service diagnostic test with the engine running and it indicated an "open loop" until the engine warmed up, then it showed a "closed loop" mode which is supposedly normal when the engine reaches enough temperature for the O2 sensor to feed back a signal to the ECM. I checked the input voltage to the MAP sensor and it was within range. I am at a total loss as to what to try or even check next. Any help would be greatly appreciated.
| Find a
car repair manual for your Chevy Truck Repair Question. |
By
Advertisment,
| Find a
Posted at Wed Apr 30, 2008 4:46 pm |
By
Welkmeister,
Have Donated |
I disconnected the electric plug to the EGR solenoid and it ran good. Plugged the connector back in and it did the spit-n-sputter again. Since the EGR valve is new would it be safe to say that the solenoid valve is faulty? I tested the vacuum on the solenoid inlet and it had good negative pressure but no negative passed through the solenoid. Also, on the outlet side of the solenoid there is two ports, one for the EGR and the other is supposed to be a vent. I noticed that there was a cap on the vent side.....should that be capped or should it be able to vent to atmosphere? What's the best way to test the solenoid?
| Find a
Posted at Thu May 01, 2008 4:52 pm |
By
Welkmeister,
Have Donated |
I tested the solenoid by removing the unit and applying 12V across the input terminals. This should have opened the solenoid allowing vacuum to pass from the manifold side (input side) to the EGR side. The solenoid did not move to allow the vacuum to pass. I assume that since it did not activate then the solenoid is defective. Since it's a relatively inexpensive part I put one on order and I will install it tomorrow and do another test run. The truck runs great when the electrical connection to the solenoid valve is unhooked so this almost has to be the culprit.
| Find a
Posted at Sat May 03, 2008 5:24 am |
By
Welkmeister,
Have Donated |
I installed a new solenoid valve and the truck runs great! Thanks for your help.
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
