Auto Repair Chat - Ask a Question, Get a FREE Answer.
Go Back
1993 Chevy S-10 timing belt
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Posted at Wed Jul 02, 2008 6:37 pm |
By
BIGBLUE,
Likes cars! |
Give Feedback | Votes: 0 |
1993 Chevy S-10 6 cyl Four Wheel Drive Automatic 150000 miles
If the timing belt was bad would my truck start
| Find a
car repair manual for your Chevy S-10 Repair Question. |
By
Advertisment,
| Find a
Posted at Thu Jul 03, 2008 6:25 pm |
By
obxautomedic,
Moderator |
  (52) Give Feedback | Votes: 6 |
| BIGBLUE wrote: | 1993 Chevy S-10 6 cyl Four Wheel Drive Automatic 150000 miles
If the timing belt was bad would my truck start |
Your truck won't start if Belt Broke or Jumped Timing. However, you vehicle has a chain not a belt. So, if it jumped timing it won't start and it would backfire.
Have you check to make sure you have fuel getting to the injectors and spark to the plugs?
Also check the Cap and Rotor. When was the last Tune Up?
| Find a
Posted at Fri Jul 04, 2008 3:25 am |
By
BIGBLUE,
Likes cars! |
CHANGED SPARK PLUGS, WIRES, DISTRIBUTER CAP AND ROTOR ABOUT 6 WEEKS AGO, HAS NEW PUMP, FILTER, MAP SENSOR, THROTTLE SENSOR, WILL START SOMETIMES AND IDLE BUT STILL UNDRIVEABLE.
| Find a
Posted at Sat Jul 05, 2008 2:14 pm |
By
BIGBLUE,
Likes cars! |
IT WILL IDLE AND WHEN I HIT THE GAS HARD IT WILL SPUTTER AND THE DIE OUT, SOMETIMES IT WILL START BACK UP SOMETIMES IT WILL NOT, CHANGED IDLE AIR CONTROL AND MAP ALREADY.
| Find a
Posted at Sun Jul 06, 2008 4:41 am |
By
BIGBLUE,
Likes cars! |
were is the test port and the pressure regulater located?
What is the correct pressure for my blazer
| Find a
Posted at Sun Jul 06, 2008 3:04 pm |
By
obxautomedic,
Moderator |
| BIGBLUE wrote: | were is the test port and the pressure regulater located?
What is the correct pressure for my blazer |
The test port is on the left rear of the intake.
Fuel Pressure:
4.3 Vin W (8TH DIGIT OF VIN) - 55- 61 PSI
4.3 Vin Z Torbo - 38 - 43
Here is a pic of were the Regulator is....
You will have to remove the Plenum to get to it.
| Find a
Posted at Mon Jul 07, 2008 3:05 pm |
By
BIGBLUE,
Likes cars! |
I'll give this a try and get back to you thanks
| Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
