Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1993 Chevy Cheyenne 4 cyl Four Wheel Drive Manual 150000 miles
When I step on the gas hard it bogs down and when I let off of the acclerator a little it acclerates. It also has trouble going up hill because of this.
First check/replace your fuel filter,you may have a fuel pump problem if the filter doesnt cure it.I am assuming your ignition system is good and your timing is correct.
Does this happen when the engine is cold and hot?
Does it ping and act like its starving for fuel?If it only happens after it has warmed up you may have a faulty MAP sensor.
my truck also has performance loss when I floor it. Does yours stutter badly because that is what mine does. And yes mine does this after it is warmed up. If I start it again it is good for a few seconds and then stutters again.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
