Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Manual Ask a Car Repair Question
Auto Repair Manual Car Questions by Manufacturer
Auto Repair Talk Auto Questions by Topic
Vehicle Repair Car Repair Forum
Auto Repair Talk Car Repair Troubleshooting
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Video Series
Vehicle Repair How to Use Test Equipment
Auto Repair Manual Car Maintenance Information
Vehicle Repair Service Engine Soon Light
Vehicle Repair Car Parts and Equipment Store
Vehicle Repair How Does it Work?
Vehicle Repair Safety Inspection
Auto Repair Manual Online Car Repair Manual
Vehicle Repair Smog Test Preparation
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1997 Chevy Silverado Fu...
Auto Repair1990 Ford F150
Auto Repair2006 Vauxhall Monaro En...
Auto Repair1995 Other Ford Models A...
Auto Repair1995 Chevy Lumina Rough...
Auto Repair1994 Honda Accord Drain...
Auto Repair1999 Other Suzuki Models...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Chevy Cavalier Wont crank
Welcome to our question and answer forum where over 6,000 free auto repair questions are answered every month, after you have completed our free signup you will able to ask a question and receive an answer from one of our many forum members.
If you elect to donate any small amount of money we will assign one of our 2CarPros Certified Repair Technicians to answer your question. Questions with donations are answered promptly and 100% of the donation is awarded to the technician helping you.
New Watch our new Car Repair Video Series with Ken Lavacot.
Goto page 1, 2  Next
Posted at Thu May 15, 2008 5:23 pm
By dan1486, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1993 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
Ok well I got a 1993 Cavalier 2.2L. About 2 weeks ago I had the same problem the car would not crank at all so I had it towed to my house and was messing with it and put a new starter on it adn then found out 1 of the ignition wires were not connected tight together under the column. So now 3 weeks later I have the same issue car wotn crank at all. I got power from the battery and to the starter. I kept the key to the run position and messed with the ignition wires still wont start. I am also getting power from the ignition.. Im stuck help please
Find diagnostic tools, replacement parts or locate a car repair manual for your Chevy Cavalier Repair Question.
By Advertisment,
Posted at Thu May 15, 2008 10:15 pm
By Buzzsaw, Tech level 7
Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4Reputation: 216.4 (216) Give Feedback | Votes: 13
where did you buy your parts at? (starter)
do your lights dim when you try to start it?
Posted at Fri May 16, 2008 3:52 am
I bought the starter at Auto Zone... The lights do not dim at all... Even when the key turns to the start position the starter solenoid doesnt click
Posted at Fri May 16, 2008 3:55 am
By mastertechtim, Tech level 9
Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2Reputation: 282.2 (282) Give Feedback | Votes: 19
check the purple wire at the starter for power, if there is power there then you have a bad starter, if no power then you need to check wires under the dash for power. the wire under the dash will be a fat yellow wire or purple wire, check for power there and let us know
Posted at Fri May 16, 2008 3:57 am
Ok I will try that tonight when I get home from work. Do you think maybe it could be the ignition switch at all?
Posted at Fri May 16, 2008 5:57 am
put a test light on that purple wire at the starter while your watching it have some one turn the key to the start position. if it lights up that junk autozone starter is bad, dont buy parts there, fluids and things like that yes, parts no
Posted at Fri May 16, 2008 2:42 pm
Well I tried that and it doesnt light up at all.....so Im lost lol
Posted at Fri May 16, 2008 3:00 pm
yes it could be the ignition switch. check for power at the yellow wire at the ignition switch. if ok there then you need to check the transmission neutral safety switch. try starting in neutral or reverse or drive and see if that helps
Posted at Fri May 16, 2008 6:07 pm
Ok Not the ignition switch I even swaped it out for a enw one no start... I checked the yellow wire from the switch when I turn it on it lights up.. I checked the purple wire going to the starter and it doesnt light when I turn the key.. I checked everything I get power from the ignition switch, to the starter everything.. Im really lost on this one
Posted at Sat May 17, 2008 3:29 am
dont be lost you are almost there. the problem is most likely the neutral safety switch on the transmission. you are almost there dont give up, you are rounding third and heading for home. under the hood where the shifter linkage connects to the transmission you will see a electrical plug with the fat yellow wire and the fat purple wire. test for power first at the yellow wire while cranking, if no power the yellow wire is broken between the ignition switch and there. if there is power at the yellow check the purple for power, if no power at the purple then replace the neutral safety switch and it will start.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
