Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair2003 Volkswagen Jetta Br...
Auto Repair1995 Isuzu Trooper Slow ...
Auto Repair1969 Chevy Corvette Brakes
Auto Repair2001 Oldsmobile Bravada ...
Auto Repair2005 Toyota Corolla Sque...
Auto Repair1999 Honda Prelude Shift...
Auto Repair2003 Ford Explorer Anti ...
Auto Repair1989 Chevy Celebrity Rece...
Auto Repair2001 Dodge Ram Sensor Lo...
Auto Repair2004 Chevy Cavalier 2004...
Auto Repair1990 Ford Aerostar Runs ...
Auto Repair2004 Chevy Silverado Spe...
Auto Repair1993 Lincoln Continental
Auto Repair1987 Ford Tempo Dies, Wi...
Auto Repair2005 Honda Accord Window...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Chevy Cavalier Wont crank
New Watch our new Car Repair Video Series with Ken Lavacot.
Goto page 1, 2  Next
Posted at Thu May 15, 2008 5:23 pm
By dan1486, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1993 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
Ok well I got a 1993 Cavalier 2.2L. About 2 weeks ago I had the same problem the car would not crank at all so I had it towed to my house and was messing with it and put a new starter on it adn then found out 1 of the ignition wires were not connected tight together under the column. So now 3 weeks later I have the same issue car wotn crank at all. I got power from the battery and to the starter. I kept the key to the run position and messed with the ignition wires still wont start. I am also getting power from the ignition.. Im stuck help please
Find a repair manual for your Chevy Cavalier Repair Question.
By Advertisment,
Posted at Thu May 15, 2008 10:15 pm
By Buzzsaw, Tech level 7
Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4Reputation: 214.4 (214) Give Feedback | Votes: 11
where did you buy your parts at? (starter)
do your lights dim when you try to start it?
Posted at Fri May 16, 2008 3:52 am
I bought the starter at Auto Zone... The lights do not dim at all... Even when the key turns to the start position the starter solenoid doesnt click
Posted at Fri May 16, 2008 3:55 am
By mastertechtim, Tech level 9
Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2Reputation: 245.2 (245) Give Feedback | Votes: 16
check the purple wire at the starter for power, if there is power there then you have a bad starter, if no power then you need to check wires under the dash for power. the wire under the dash will be a fat yellow wire or purple wire, check for power there and let us know
Posted at Fri May 16, 2008 3:57 am
Ok I will try that tonight when I get home from work. Do you think maybe it could be the ignition switch at all?
Posted at Fri May 16, 2008 5:57 am
put a test light on that purple wire at the starter while your watching it have some one turn the key to the start position. if it lights up that junk autozone starter is bad, dont buy parts there, fluids and things like that yes, parts no
Posted at Fri May 16, 2008 2:42 pm
Well I tried that and it doesnt light up at all.....so Im lost lol
Posted at Fri May 16, 2008 3:00 pm
yes it could be the ignition switch. check for power at the yellow wire at the ignition switch. if ok there then you need to check the transmission neutral safety switch. try starting in neutral or reverse or drive and see if that helps
Posted at Fri May 16, 2008 6:07 pm
Ok Not the ignition switch I even swaped it out for a enw one no start... I checked the yellow wire from the switch when I turn it on it lights up.. I checked the purple wire going to the starter and it doesnt light when I turn the key.. I checked everything I get power from the ignition switch, to the starter everything.. Im really lost on this one
Posted at Sat May 17, 2008 3:29 am
dont be lost you are almost there. the problem is most likely the neutral safety switch on the transmission. you are almost there dont give up, you are rounding third and heading for home. under the hood where the shifter linkage connects to the transmission you will see a electrical plug with the fat yellow wire and the fat purple wire. test for power first at the yellow wire while cranking, if no power the yellow wire is broken between the ignition switch and there. if there is power at the yellow check the purple for power, if no power at the purple then replace the neutral safety switch and it will start.
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
