Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1991 Pontiac Grand Prix ...
Auto Repair1996 Dodge Ram Engine D...
Auto Repair2004 Bmw M3
Auto Repair1989 Cadillac Deville P...
Auto Repair1990 Toyota Corolla Intake
Auto Repair1996 Ford Explorer Fuel...
Auto Repair2002 Honda Odyssey Auto...
Auto Repair More Repair Topics...
Car Repair Talk - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1993 Cadillac El Dorado Engine Stalls
Posted at Mon Jun 29, 2009 7:35 pm
By lawisnotblind, Likes to hang around!
Give Feedback | Votes: 0
Engine Performance problem
1993 Cadillac El Dorado V8 Front Wheel Drive Automatic 104000 miles
This is the problem for me. Over the past year, the fuel sending unit was replaced, along with the gas filter, fuel pressure regulator, map sensor, ait sensor, tps, new plugs & wires and both crankshaft sensors. Also, I have no codes. When I first start the car it runs absolutely great. Drove up to the freeway and went 10 miles one way and returned. I was driving down my street @ 25 mph and paused to turn into driveway and the car quietly and suddenly stalled. The temp reached and remain at around 203-212 degrees. At one point it reached 223 and immediately went back to 207. I drove the car around town the next day and while leaving the post office, I pulled to the stop sign and it just stalled again. It restarts immediately and I drove home with no problems at all, but I did notice that it did began to feel like it was running a bit rough. The next day, I drove it and after about 30 mins of running around town, it stalled again and took about 4 tries to restart in about 3 mins. My brother has the exact same kind of car, model and year and no problems at all. Can anyone offer any ideas? My wife will no longer touch the car!!!
Thank you, Cliff
Find a car repair manual for your Cadillac El Dorado Repair Question.
Posted at Mon Jun 29, 2009 9:48 pm
By gstacey, Problem solver!
Reputation: 914.5Reputation: 914.5Reputation: 914.5Reputation: 914.5Reputation: 914.5Reputation: 914.5Reputation: 914.5Reputation: 914.5Reputation: 914.5 (915) Give Feedback | Votes: 16
Does it have the original plugs and wires(wires will have cyl# on them). It could be electrical interference from the wires causing the ignition control to shut down. It could also have an EGR valve sticking open, although at 25 mph you should get little/no EGR. Typically after the egr goes to 100%(45mph-), it sticks full open and dies after cruising.
Posted at Mon Jun 29, 2009 10:47 pm
Thanks for responding. The plugs and wires were also changed. The EGR valve was NOT changed, but I did attempt to clean it out some time ago.
Posted at Tue Jun 30, 2009 8:11 pm
Never had much success with cleaning them out. If the egr is sticking, it will run rough, you can keep it running with throttle though, it is basically a large vacuum leak. If it won't start, tap on the base of it with something metallic, and see if it changes. Or even try tapping on it if it is running rough. One other thing to consider, and may be the higher of the probabilities, is the idle speed control motor. It has a nose switch as part of the unit, and if that switch is still indicating the throttle at idle when it is not, it will retract all the way trying to control the speed, and the result will be a stall. This can also create a hard start for a short time until the shaft extends opening the throttle plate. Considering your conditions, and this happening around town, it is the strongest of the possibilities. You might be able to confirm this by disconnecting the isc when the vehicle is at a decent idle speed, and driving like you've been. If it no longer stalls, plug it in and see if it returns. Or, check it after a stall. If the ISC shaft is fully retracted to where there is a gap between it and the cam, that is your cause.
Posted at Thu Jul 02, 2009 6:55 pm
Hi gstacy, since I changed the plugs and checked all wires for proper resistance, I'll change the ISC and see what happens. If that doesn't do it, I'll also change the EGR valve. I might even do both, one after the other. So if the ISC works, I may still do the EGR for preventiveness. I'll let you know. Thanks so much, Cliff
Posted at Thu Jul 02, 2009 8:35 pm
You may run into an issue with having to do an idle learn to clear a check engine light, after an ISC replacement.
Posted at Thu Jul 02, 2009 9:27 pm
I understand what you are saying about the idle learn and I just read a page that gave an 18 step procedure for doing a TP sensor/idle learn procedure, so once I replace the ISC, i'll do this procedure. Thanks for the heads up.
Cliff
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
