Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1979 Chevy Truck Fuel Ta...
Auto Repair1972 Gmc C1500 Engine Co...
Auto Repair1993 Jeep Cherokee Fuel ...
Auto Repair2000 Chevy Malibu Surgin...
Auto Repair2000 Plymouth Voyager
Auto Repair2000 Nissan Maxima Car G...
Auto Repair1999 Ford Explorer
Auto Repair2001 Chevy Impala 25 Amp...
Auto Repair2000 Chrysler Van Egr Valve
Auto Repair2005 Chrysler Town And Co...
Auto Repair1988 Bmw 535 Horn By The...
Auto Repair1996 Honda Civic
Auto Repair1998 Lincoln Town Car Ro...
Auto Repair1996 Dodge Dakota Rough ...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Buick Skylark STALLING
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu Apr 10, 2008 6:08 am
By krandrews1, Have Donated
(6) Give Feedback | Votes: 0
Engine Mechanical problem
1993 Buick Skylark 4 cyl Front Wheel Drive Automatic 135000 miles
THIS CAR STALLS IF YOU COME TO A STOP AFTER
DRIVING OVER 35 MPH.
THERE ARE MOLDED HOSESTHAT MEET AT A PLASTIC BOX ABOUT 5 INCHES LONG AND 3 INCHES HIGH ON THE INTAKE.
ONE OF THE HOSES (1/2 INCH OR 3/8 INCH) HAS A PLASTIC TUBE INSIDE IT WITH AN ELECTRICAL CONNECTOR IT GOES BACK TO THE INTAKE.
A 3/4 INCH MOLDED HOSE IS ATTACHED TO THE BOTTOM OF THE BOX, IT GOES DOWN SOME WHERE NEAR THE AC COMPRESSOR.
THERE IS ANOTHER HOSE (1/2 INCH OR 3/8 INCH)
THAT CONNECTS TO THE FRONT OF THE BOX AND GOES TO WHERE THE AIR FILTER IS HOUSED.
THERE IS ANOTHER COMMON SIZE VACCUM HOSE I THINK IT IS ATTACHED TO THE INTAKE.
THE HOSES ARE ROTTING AND CRACKED.
THE PLASTIC TUBE WITH THE ELECTRICAL CONNECTOR IS CLOGGED.
I NEED THE NAME OF THE HOSES AND THE PLASTIC TUBE WITH THE ELECTRICAL CONNECTOR.
PART STORES HAVE NO IDEA WHAT THESE PARTS ARE.
WHERE DOES THE 3/4 HOSE GO?
WHAT IS THE NAME OF THE BOX THE HOSES ARE ATTACHED TO ?.
I WANT TO REPACE THESE PARTS.
Find a repair manual for your Buick Skylark Repair Question.
By Advertisment,
Posted at Thu May 15, 2008 8:49 pm
By wildfirev9, Have Donated
Does it start up after stalling then stall again after putting it into gear?
If so, that problem is the transmission lockup solenoid.
A temporary quick fix is disconnect the electric connector on the front of the trans. If it quits stalling, then replace the lockup solenoid located inside the END pan on the trans. Do a trans filter and fluid service while you're at it and add some LUCAS trans conditioner.
The large vacuum line goes to the brake booster.
The others are emissions related.
Sounds like you need to go to a highly recommended certified mechanic.
All of us appreciate the donation.
Hope I've been able to help. VIC
wildfirev9
Posted at Fri May 16, 2008 8:51 am
THERE IS A HOSE (1/2 INCH OR 3/8 INCH) THAT HAS A PLASTIC TUBE INSIDE IT WITH AN
ELECTRICAL CONNECTOR IT GOES FROM THE AIR
OIL SEPERATOR TO THE INTAKE MANIFOLD.
THIS IS A 2.3 LITER QUAD FOUR ENGINE.
WHAT IS THE SENSOR CALLED?
I WANT TO REPLACE IT BECAUSE IT WAS CLOGGED WITH OIL SLUDGE.
(I TRACED THE STALLING TO MAP SENSOR.)
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
