The brake fluid is contaminated with oil or tranny fluid, ALL rubber parts must be replaced, and the steel lines flushed with alcohol and compressed air!
The rubber has swelled because of the oil! If you have a hydraboost check it for a front seal leak by pulling the master off the booster!
Calipers wheel cyls, hoses and combination valve must be changed, ans the Master too!
