Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1993 Buick Roadmaster V8 Two Wheel Drive Automatic 180000 miles
I have disconnected the fuel lines from the carb and have no sign of fuel to the Carb. when I turn the ignition on I can hear the fuel pump start pumping and then stop. if i crank the car i hear the pump start and stop. Help
If the fuel filter isn't plugged solid and you hear the pump, it must be bad. Even if it runs, it may not be pumping fuel. Check for pressure before the fuel filter.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
