Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Ford F250
Auto Repair1989 Ford Probe Dash Li...
Auto Repair1996 Dodge Caravan Star...
Auto Repair1999 Dodge Intrepid Eng...
Auto Repair1988 Mazda B2200 Idle
Auto Repair1991 Pontiac 6000 Water...
Auto Repair1991 Pontiac 6000 Chang...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1993 Audi Quattro DIES AFTER 10 MIN
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Sep 27, 2008 1:51 pm
By CMCAUTOWORKS, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1993 Audi Quattro V8 All Wheel Drive Automatic 110000 miles
THIS CAR RUNS GREAT FOR 5 MIN THEN DIES AND WON'T RESTART UNTILL 2-3 HOURS LATER--JUST BOUGHT AND HAVE NO HISTORY--BUT KNOW NEITHER BANK HAS SPARK-HAVE NOT CHECKED FUEL PRESSURE
Find a car repair manual for your Audi Quattro Repair Question.
Posted at Sat Sep 27, 2008 8:34 pm
By 2CarPro Ken, Certified ASE Technician
Reputation: 145Reputation: 145Reputation: 145Reputation: 145Reputation: 145Reputation: 145Reputation: 145 (145) Give Feedback | Votes: 9
Hi, thanks for contacting us, I would go to this page and follow the tests.
http://www.2carpros.com/first_things/engine_stalls.htm
let me know how it goes.
Posted at Sun Sep 28, 2008 8:09 am
LINK WASN'T TO HELPFULL---BUT I DID PERFORM BLINK CODES THIS AM= 2 CODES CAME UP---RAN CAR UNTILL IT DIED AND PERFORMED BLINK CODE PROCEDURE TO AUDI--CODE 2111-SPEED SENSOR CAME UP--WHICH COULD BE NORMAL SINCE CAR WAS TESTED NOT RUNNING-ALSO CODE 1111 CAME UP=FAULTY ECM---BUT COULD BE GROUND PROBLEMS---I AM CHECKING THOSE NOW--BUT WILL RESET ECM AND TRY TO GET CODES WHILE IT RUNS FOR THE 5 MIN IT DOES---ANYMORE SUGGESTIONS??? GENERIC INFORMATION ISN'T VERY HELPFULL--I'VE BEEN ASE CERTIFIED FOR 35+ YEARS--HAVE RUN MY OWN SHOP ETC... JUST NOT FAMILIAR WITH THIS VEHICLE ABD THOUGHT SOMEONE THERE MAY HAVE A SIMILAR EXPERIENCE
THANKS ANYWAY--BUT IF YOU THINK OF SOMETHING LET ME KNOW
Posted at Sun Sep 28, 2008 9:13 am
That link shows you fuel pressure testing and igntion system testing, when the engine dies what do you loose fuel or spark?
Posted at Sun Sep 28, 2008 11:19 am
CHECKED CODES=1111=FAULTY ECM BUT INFO I HAVE SAYS TO CHECK GROUNDS AT ECM--BUT SIMILAR EXPERIENCE ON SAME VINTAGE BMWS/WITH SAME SYMTOMS TELLS ME ECM--
Posted at Sun Sep 28, 2008 4:31 pm
With a wiring diagram check the main system grounds using a multimeter. If all the grounds check out replace the ECM.
Posted at Tue Oct 07, 2008 12:27 pm
PROBLEM WAS SPEED SENSOR ON BELL HOUSING--GLAD I COULDN'T FIND ECM TO TRY--TRACED ALL WIRES FROM ALL SENSORS AND EXPERIENCE TOLD ME IT WASN'T ECM--CHECKED RESITANCE OF SPEED SENSOR WHEN COLD=1KOHM--WHEN CAR = INFINITE----CHECKED AT ECM BECAUSE SENSORS VERY HARD TO GET, THANKS ANYWAY
MC
Posted at Tue Oct 07, 2008 1:22 pm
so it was the speed sensor, the first thing the computer caught,, why didnt you repalce it in the first place?
Posted at Wed Oct 08, 2008 4:15 am
BECAUSE ACCORDING TO AUDI'S REPAIR PROCEDURE THAT CODE WILL COME UP ANYTIME THE MOTOR IS CRANKED AND DOES NOT START(AS IN THIS CASE WHEN TESTED) AND WILL BE BE STORED--ALSO ECM REPLACEMENT CODE CAME UP ALSO---I DON'T BELIEVE IN THROWING PARTS AT VEHICLES--I LIKE TO "PROVE/TEST" FOR WHAT THE PROBLEM IS--IT JUST SO HAPPENS THAT OBD SYSTEMS ARE ONLY AS GOOD AS THEY ARE PROGRAMED AND ARE NOT INFALLIBLE--IN THIS CASE I TESTED SEVERAL SENSORS I THOUGHT COULD BE THE CAUSE---AND WHEN RESISTANCE AT ECM WENT FROM 1KOHM (NORMAL) TO INFINITE WHEN CAR DIED FOR SPEED SENSOR BUT REMAINED NORMAL FOR CRANK SENSOR I HAD A GOOD IDEA WHAT THE CULPRIT WAS--IT'S NOT UNUSUAL FOR UNPREDICTABLE ELECTRICAL PROBLEMS THAT AREN'T IN THE NORMAL REPAIR FLOW CHARTS TO CAUSE WEIRD RESULTS---ALSO, WHEN CHECKING CODES AFTER LETTING CAR SIT UNTILL IT WOULD RESTART--WITHOUT CRANKING IN A NO START SITUATION--NO CODE FOR SPEED SENSOR WOULD COME UP--ECM DIDN'T PICK IT UP AT TIME OF FAILURE???? INTERESTING BUT GOES BACK TO TO THE WAY I HAVE BEEN TRAINED CHECK AND DOUBLE CHECK YOUR RESULTS TO CONFIRM DIAGNOSIS BEFORE THROWING PARTS ON--ESPECIALLY IN VEHICLES THAT ARE SOMEWHAT RARE AND PARTS ARE EXPENSIVE--
THANKS FOR YOUR HELP--
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
