1993 Acura Integra air,fuel,spark still wont start
Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Electrical problem
1993 Acura Integra 4 cyl Front Wheel Drive Automatic 160,00 miles
I recently aquired a 1993 acura integra 1.8liter.the ke on the exhaust gear was worn ane it was missing.i repaired it and did a compression testand all cylinders are good.i put it all together and tried to start it and nothing. i did the usual checks and the furl pump is good the ignition system is getting plenty of fire to the plugs and it is grtting air. so much for the good old days where fuel fire and air meant it eould run. the engine turns over and ive tried turning the distributor to see if it will fire up but nothing it just turns over and dont try to crank.i re checked my timing marks and they are on so what am i not doing rite? please help im at a loss. Dylan
Still same as good old days, with the 3, it should start.
Did you get the firing order correct?
Did you check the static timing?
What is the colour of the sparks?
Does the Check engine light goes off after 2 seconds of ignition switch on?
as far as statick timing i double checked all my marks on the crank pulley and the 2 overhead cam gears its on point, the spark out the plug is a drite dlus eith a erd point at point of ground. the firing order is also correct. hmmmmm as for the sheck engine lite i dont remember, what would be the issue if the light stays on.? it just spins and no sighn of even trying to fire. and all my elements are there. F<F<& AIR. id appreciate any help you have to give. im more used to big block 350;s lol Dylan
Sorry, I only understand English and your explanation of the spark color is not in English.
If it is not bluish and rather is reddish or orange, the coil is weak.
If the Check engine light does not go off after 2 seconds it could be a faulty ECM or main relay.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
