1992 Volvo 940 surge and stall
Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Dodge Neon Odd Smell
Auto Repair1996 Toyota 4runner How...
Auto Repair1994 Ford Tempo Runs Ro...
Auto Repair2001 Ford Ranger Daylig...
Auto Repair1998 Ford Excursion
Auto Repair1995 Mazda Protege Cold...
Auto Repair1989 Jeep Cherokee Keep...
Auto Repair More Repair Topics...
Site Advertising
Auto Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Goto page 1, 2  Next
Posted at Tue Apr 08, 2008 7:29 pm
By jwallace314, Have Donated
Give Feedback | Votes: 0
Engine Performance problem
1992 Volvo 940 Front Wheel Drive Automatic 154000 miles
Volvo 940GL 4cyl, 1992.
Cranks twice then stops cranking. If I hold the key in the crank position it will pause and try to turn over again. The car has not been running smoothly. I inspected the Radio (Noise) Suppression Relay by opening the case and visually inspecting, all looks good. I resiliconed the unit and put it back in place. It started okay right after I put the relay back in, but at 2500-3000rpm the car cuts out until the rpms drop down below 2500. So as the automatic transmission moves through the gears as soon as the engine speed hits these rpm it cuts out again. Sometimes, rarely, it runs smooth even at 2500-3000 rpm. Is there a particular sensor that needs to be changed? What do you make of this problem
Find a car repair manual for your Volvo 940 Repair Question.
Posted at Wed Apr 09, 2008 7:44 am
By 2CarPro Ken, Certified ASE Technician
Reputation: 145Reputation: 145Reputation: 145Reputation: 145Reputation: 145Reputation: 145Reputation: 145 (145) Give Feedback | Votes: 9
Volvos in that year had a problem with the wiring harness, plus check the connector and look for wires that have bare spots. The insulation dilapidates and wires become exposed. Please inspect and get back to me.
Posted at Fri Apr 11, 2008 8:43 am
Hello Ken,
I checked the obvious wire harnesses, the ones I could visually inspect. I found a two-wire shielded harness with significant damage to the foil shield. The number on the wire is: Volvo 3547847. It is runs along the firewall and appears to attach to the top of the transmission on the drivers side. Could this affect the rpms around 2500-3000?
Posted at Fri Apr 11, 2008 11:04 am
Have you had a tune up lately?. It sounds like the ignition could be breaking down and causing the engine to missfire. please let me know
Posted at Fri Apr 11, 2008 12:15 pm
The car had a complete tune 10 months ago, but has only been driven 50 miles since the work was done. It past its emissions test two months ago, but has not run well enough to put any mileage on. The mechanic that did the work typically works on Japanese cars. When I recently called him he thought maybe it was an exhaust restriction. Is there an rpm sensor that may have gone bad?
Posted at Fri May 16, 2008 12:25 pm
This 1992 Volvo 940GL still is not running. Three weeks ago it just died on the highway and we had to have it towed home. A week later it starts again and my son drives it to the store and back with no problems. Systematically, what should we replace first to try and find the issue? Could it be a bad coil getting too hot and shorting out, then cooling and starting again? You mentioned the wiring harness can harbor issues and other forums mention sensors going awry. What’s the next step?
Posted at Fri May 23, 2008 9:26 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1Reputation: 682.1 (682) Give Feedback | Votes: 80
You could throw parts at it til the end of time and still may not get it. Need to do some basic tests when it is dead, spark and fuel pressure, if both are there check for injector pulse with a noid light. If the car is running, there isnt really a problem to find unfortunatly
Posted at Fri May 23, 2008 11:17 am
Thanks for the reply. I went to Dave's Volvo Page - Lake Elsinore, CA 92530 www.davebarton.com and ordered the three basic parts listed below. After reading posts all over the internet, these sensors and relays seemed to be the place to start and his site confirmed.
-Crank Sensor 3547847 $43.00
-Relay 3523608 $38.00
-Noise Suppression Relay 1323592 $36.00
Posted at Fri May 23, 2008 1:25 pm
I can see the crank sensor causing intermittent stalling, which relay is it ? Not sure if the noise supressor will cause it either, but hey he's the Volvo expert
Posted at Fri May 23, 2008 4:23 pm
3523608 New Relay, Original Volvo (Stribel),
WHITE (LH-Jetronic Fuel Injection),
Goto page 1, 2  Next
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
