Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2004 Dodge Dakota Engin...
Auto Repair1997 Chevy Aveo Serv En...
Auto Repair1996 Honda Accord Overa...
Auto Repair1988 Toyota Supra Engin...
Auto Repair1996 Dodge Intrepid Eng...
Auto Repair1998 Chevy Lumina I Hav...
Auto Repair1995 Toyota Corolla Pow...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1992 Volvo 940 short in compressor - blowing fuse / brake r
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Aug 23, 2008 4:23 pm
By jayco26foot, Have Donated
Give Feedback | Votes: 0
Air Conditioning problem
1992 Volvo 940 4 cyl Two Wheel Drive Automatic 145000 miles
I was told that I have a short in the compressor that is causing the 30amp fuse to blow - I can run the fan on lower speed without blowing fuse - does that sound correct? Also I need to recharge - the owner's manual says to use "Volvo refrigerant" - Can is use R134A and do myslef - have done my other vehicles.
Also I was told you cannot turn the rotors on a Volvo when you replace the brake pads - they have to be replaced - is that true? Can you just replace the brake pads without turning the rotors - I know it will not be smooth braking - but can you take this approach - the rotors are fairly expensive. We only drive this car about 6K miles a year.
Find a car repair manual for your Volvo 940 Repair Question.
Posted at Sat Aug 23, 2008 6:32 pm
By KHLow2008, Moderator
Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7 (175) Give Feedback | Votes: 12
Hi jayco26foot,
Thak you for the donation.
If there is any shorting in the compressor, you cannot control its running speed. You can only control the blower speed. When fuse keeps blowing, you need to check the cause and rectify it, sometimes is it due to bad connections and can heat up badly which can turn into a fire hazard.
R134A is of the correct spec so I don't see why it cannot be used.
To reface or replace rotors depends on the braking efficiency required. I don't believe everybody dirvies around with new rotors each and every time brake pads are replaced. I have replaced my vehicle brake pads at least 5 times but never did I once replace the rotors.
Posted at Sat Aug 23, 2008 7:17 pm
Thank you for clearing up the question with the short and the coolant type. A local established Volvo repair shop advised me of the short and said that the compressor had to be repalced - due to the age of the vehicle they agreed it did not make $$ sense to pay for new compressor. He was not alarmed about a potential of a fire, based on what he found at the time - but if it continues - I will take your advice and pursue further or have it inspected by another person familiar with Volvos.
With regard to the rotors, can I assume they can be turned? If not, if new pads are installed - then the worst case senario is that it will have rough braking - the slight groves in the rotor will not make the barkes not operate properly in normal city traffic? (Assumimg there are no other issues with the braking system.) My main concern is that if I replace the pads, I am very willing to have vibration on braking - as long as it is not unsafe. The vibration at present is not that pronounced and has worked for several years - approx 20K miles. The pads are getting thin at this point. Please confirm if you see any safety issues and if you think they can be turned.
Posted at Sat Aug 23, 2008 7:37 pm
Hi jayco26foot,
Should not be much of a safety concern but you should bear in mind that the efficiency of the brakes is not going to be 100 % of what it is capable of.
Replacing the pads would do, not necessary to reface rotors if you can live with it.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
