Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Pontiac Firebird R...
Auto Repair1990 Pontiac 6000 Headl...
Auto Repair2002 Chevy Silverado Ac...
Auto Repair2004 Ford F250
Auto Repair1987 Pontiac 6000
Auto Repair2004 Chevy Impala Speed...
Auto Repair1988 Pontiac 6000 Anti ...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1992 Toyota Celica Ignition Coil
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Aug 29, 2008 1:40 pm
By BabyD, Have Donated
Give Feedback | Votes: 0
Engine Mechanical problem
1992 Toyota Celica 4 cyl Front Wheel Drive Automatic 216000 miles
Hi, I have been having problem with my car as I drive down the road it will occassionally start jerking and the engine light will come on and the rpm needle will move erratic. I first notice this in like 2005 anyway in Nov of 2006 someone suggested an ignition coil, so I had one put on, and the problem went away for appx a year and some months then the same thing happen again so i had another one put on like Feb. of this year the problem went away again, until appx 3 weeks ago. It seems it only does it when the car have been driven awhile(like when it gets hot) because It had never done it on the way to work in the morning, only when I'm on the way home from work after running several errands. It doesn't do it everyday but when it does sometime it cut off and it is kinda of hard to start back up. Could you please tell me any kind of suggestion that will help me. Thanking you in advance for your help.
Find a car repair manual for your Toyota Celica Repair Question.
Posted at Sat Aug 30, 2008 4:40 am
By 2CarPro Jack, Certified ASE Technician
Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3Reputation: 682.3 (682) Give Feedback | Votes: 80
First thing is to see if there are any codes stored in the computer.Thisis done with asmall jumper wire inserted between 2 terminals int he diagnostic connector located under the hood (see pic)
Turn key on and count the flashes of the check engine light,teh light will flash with short intervals then long ones, with 21/2 second intervals between codes (see pic)
Did you use Toyota coils when you replaced them before? Toy's are kinda strange about OEM parts lasting longer for some reason.
Posted at Sat Aug 30, 2008 9:32 am
Hi, No I didn't get the original Toyota Coil. The 2 that I had put on came from Advance Auto Parts Store. Okay, now I have a question. What is a Jumper Wire? And where do I get it from?
Posted at Sun Aug 31, 2008 4:02 am
By mmprince4000, Moderator
Reputation: 71.9Reputation: 71.9Reputation: 71.9Reputation: 71.9 (72) Give Feedback | Votes: 4
You can use a paper clip bent to a "U" shape, or a short piece of wire with some small spade terminals crimped at both ends. You want to short the diagnostic terminals to put the ECM in field service mode. This will display the error codes, and it is also used to set the mechanical timing, since it removes all computer advance from the ECM.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
