Shakes or Wobbles problem
1992 Toyota 4Runner 6 cyl Four Wheel Drive Automatic 200,00 miles
I have a 1992 4Runner, 4WD, V6, automatic transmisson, 4Door, 200,000 miles. Not sure if this is a problem with all 4Runners. I have a vibration that I can not pin point. Tires are balanced. It is not the brakes. I have replace the rear driveshaft. It help a little but it is still there. The vibration starts at about 1500 rpms. Very noticeable at 3000 rpms at 50 mph but it is always there at any speed and rpm. The vibration feels like it is in the engine, transmission or transfer case. I have re-torqued the rear nut on the output shaft of the transfer case. I have put Warn manual locking hubs on the front. So I know it is not the front 4wheel drive axles. The 4Runner has never been wrecked. Thanks for your help
