Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1992 Chevy Cavalier Loca...
Auto Repair1995 Ford Contour Air Co...
Auto Repair1990 Jeep Wrangler Fuel ...
Auto Repair1986 Chevy Silverado Tra...
Auto Repair1989 Cadillac Deville
Auto Repair1995 Oldsmobile Cutlass ...
Auto Repair1999 Oldsmobile Bravada
Auto Repair2001 Dodge Dakota Automa...
Auto Repair2002 Daewoo Leganza Starter
Auto Repair2007 Alfa Romeo Spider
Auto Repair2003 Volkswagen Jetta Br...
Auto Repair1995 Isuzu Trooper Slow ...
Auto Repair1969 Chevy Corvette Brakes
Auto Repair2001 Oldsmobile Bravada ...
Auto Repair2005 Toyota Corolla Sque...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Auto Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1992 Pontiac Grand Prix Leaking steering fluid.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Mon Apr 28, 2008 12:33 pm
By Jay262, Likes cars!
Give Feedback | Votes: 0
Steering problem
1992 Pontiac Grand Prix 4 cyl Two Wheel Drive Automatic 180000 miles
My car has been leaking steering fluid for a month now so i brought in to mechanic who told me that the steering rack is needing to be replaced. Im going to do so in a couple of days but in the meantime i am getting a tapping and grinding noise sometimes when turning left. Is this a new problem or could it because of the failing steering rack?
Find a repair manual for your Pontiac Grand Prix Repair Question.
By Advertisment,
Posted at Mon Apr 28, 2008 12:36 pm
By merlin2021, Certified 2CarPros Master Technician
Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4Reputation: 532.4 (532) Give Feedback | Votes: 44
Bad racks can get noisy, and so can PS pumps running low on fluid...
Posted at Mon Apr 28, 2008 2:07 pm
To be more specific the noise is not a squelling noise as when the pump gets low on fluid. More of a tapping and grinding noise. Even after a top up of fluid i get this noise.
Posted at Mon Apr 28, 2008 11:28 pm
Only happens if the wheel is turned? Or does it do it in park?
Posted at Tue Apr 29, 2008 11:35 am
Dosent happen when car is parked only while moving. Cant narrow it down alot either then when turning left. It can be turning left while slowly backing out of the driveway or making turns out on the highway. It doest happen at every left turn only time to time but are becoming more frequent as the days go on.
Posted at Tue Apr 29, 2008 12:12 pm
Turn the wheel all the way to the left, then have a look at the axle where it goes into the hub, it the rubber boot around it torn open? If yes, what you hear is the cv joint on that side, when it looses enough grease it will click when turning. If this is your problem don't wait long to fix it, you don't have much time before the cage shatters, when that happens the car will not move!
Posted at Tue Apr 29, 2008 2:07 pm
Alright i checked the boot on both the CV joints no tears or cracks that could be seen or felt.
Posted at Tue Apr 29, 2008 11:33 pm
Jack the front end off the ground, put your hands on a tire at 3 and 9 oclock, and shake. Any movement? These noises can be loose inner or outer tie rod ends, if you buy a complete rack, they come with it! A shor rack has no outer tie rods.
Posted at Wed Apr 30, 2008 7:09 am
I will let you know the diagonoses later today the car is at the garage right now. Im pretty sure the rack was bad due to the vast amount of steering fluid lost just crossing my fingers now thats all thats wrong.
Posted at Thu May 01, 2008 3:48 pm
2 bad lower front ball joints. Diagnoses of the garage. But another question on the same topic about the steering rack should i replace the whole rack or just get a boot kit put on. There is minimal leakage but you can see the boot is broken.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
