Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Mechanical problem
1992 Other Plymouth Models 4 cyl Two Wheel Drive Manual 120000 miles
I have a 1992 plymouth laser 2.0 manual non turbo that is leaking around the oil filter bracket. It is pouring out when i start the motor. I have checked the belts and timing cover area and they are clean from oil. I cant tell if the oil filter bracket is leaking from the top and leaking down or from some where else in that general area.
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
