Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manuals
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2001 Mercury Sable Why ...
Auto Repair1996 Dodge Truck
Auto Repair2000 Other Plymouth Mode...
Auto Repair1988 Chevy Nova Idling
Auto Repair1991 Honda Civic 1991 H...
Auto Repair1995 Chevy Blazer Car D...
Auto Repair2003 Dodge Stratus Car ...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1992 Other Mitsubishi Models Twin Turbo swap?
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Fri Jun 20, 2008 1:03 am
By gto newbie, Likes cars!
Give Feedback | Votes: 0
Engine Mechanical problem
1992 Other Mitsubishi Models 6 cyl Four Wheel Drive Manual
Hi guys,
Heres the story I have a '92 Mitsi 3ltr GT3000 (GTO) Non-Turbo.
I have been given the chance to remove the twin turbo's and intercoolers from another Identical engine (other than factory fit turbos). I will only get half a day or so to remove the parts I need.
I want to make my car the twin turbo version.
Question 1, What parts do I need to take off the other car? I wanna leaving the other car running as a non-turbo.
Question 2, will I be able to just bolt these components onto my engine to make it a twin turbo?
Question 3, What parts will I have to take from my engine and put on the other to keep it running as a non-turbo, ie the air box and inlet piping. is the inlet manifold different?
cheers guys
derek
Find a car repair manual for your Other Mitsubishi Models.
By Advertisment,
Posted at Sun Jun 22, 2008 3:54 am
By KHLow2008, Moderator
Reputation: 218.9Reputation: 218.9Reputation: 218.9Reputation: 218.9Reputation: 218.9Reputation: 218.9Reputation: 218.9Reputation: 218.9Reputation: 218.9Reputation: 218.9Reputation: 218.9 (219) Give Feedback | Votes: 12
Hi derek,
You are going into the Guiness book of records if you can pull off the stunt.
Turbo and non turbo engines have different compression ratios and pistons.
Exhaust and inlet manifolds, air cleaner hoses, ECM are the normal things needed to come off. The injectors are of different calibrations.
You can bolt on the turbo, but you are goiing to blow the head gaskets or engine if you try to race drag the engine.
Posted at Sun Jun 22, 2008 2:23 pm
cheers mate, thats saved me a headache, I wont bother trying. so Im guessing that the compression is lower in the turbo engine to cope with higher revs etc?
so putting the turbos on a non-tt engine would end up being quicker and more powerful than an original twin turbo but would most likely blow right?
cheers
Posted at Mon Jun 23, 2008 5:38 am
Hi derek,
You can bolt a turbo onto a non turbo engine but you cannot boost it up to turbo specs, anything more than 0.3 bar would blow the engine easily. It would also cause premature wear as the pistons, valves, gaskets etc are not made for high boost.
Lower compression is to cope with higher compression when boost is available.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
