Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Drive Train Axles Bearings problem
1992 Nissan Truck 6 cyl Four Wheel Drive Automatic 290000 miles
I have a 92 Nissan Safari swb auto and everytime I drive i can hear a rattling noise coming from my front r hubs. It use to be on the left but I took it in to get it fixed but now it's transfered to the right side. I don't wanna take it in again as i paid an excessesive amount. Any suggestions?? Thanks in advance!!
is it mostly when you turn corners or is it just all the time? because I think that you may have a bad cvjoint. or a hub assembly but IM leaning more towards a cv joint
what did the shop say when you brought it in the first time and fixed the first side? It sounds like several things, someone is gonna have to look at it. because its sounds to general and it may not even be from the hub it could be from one of the pulleys, but just sounds like its from the hub
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
