Professional Mechanics Online Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Car Repair Home
Auto Repair Manual Auto Repair by Topic
Auto Repair Manual Auto Repair by Manufacturer
Auto Repair Talk Ask a Car Repair Question
Vehicle Repair Car Repair Video Series
Auto Repair Talk Car Repair Forum
Vehicle Repair How to Repair or Service
Vehicle Repair Car Repair Troubleshooting
Vehicle Repair How Does it Work?
Auto Repair Manual Car Maintenance
Vehicle Repair Online Repair Manual
Vehicle Repair Discount Auto Parts
Vehicle Repair Car Safety Inspection
Vehicle Repair Smog Test
Auto Repair Manual Diagnostic Trouble Codes
Vehicle Repair Engine Code Scanner
Vehicle Repair Avoid Car Repair Rip Offs
Car Repair Search Search Our Website
Car Repair Questions Auto Term Abbreviations
Search Website
Recent Repair Topics
Auto Repair1992 Chevy Cavalier Loca...
Auto Repair1995 Ford Contour Air Co...
Auto Repair1990 Jeep Wrangler Fuel ...
Auto Repair1986 Chevy Silverado Tra...
Auto Repair1989 Cadillac Deville
Auto Repair1995 Oldsmobile Cutlass ...
Auto Repair1999 Oldsmobile Bravada
Auto Repair2001 Dodge Dakota Automa...
Auto Repair2002 Daewoo Leganza Starter
Auto Repair2007 Alfa Romeo Spider
Auto Repair2003 Volkswagen Jetta Br...
Auto Repair1995 Isuzu Trooper Slow ...
Auto Repair1969 Chevy Corvette Brakes
Auto Repair2001 Oldsmobile Bravada ...
Auto Repair2005 Toyota Corolla Sque...
Auto Repair More Repair Topics...
Latest Repair Videos
Auto Repair Motor Oil and Filter Video
Auto Repair Engine Air Filter Video
Auto Repair Air Cabin Filter Video
Car Repair Chat - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1992 Nissan Sentra I need help.
New Watch our new Car Repair Video Series with Ken Lavacot.
Posted at Thu May 08, 2008 5:09 pm
By ccarrion5279, Have Donated
Give Feedback | Votes: 0
Electrical problem
1992 Nissan Sentra 4 cyl Front Wheel Drive Automatic 92000 miles
During the past 6 months I have gone through 4 alternators, and they keep failing. It starts when I notice the radio turn off while driving, then the car starts to stall and turn back on, finally it will stall and not turn back on at all. I have no clue what is causing the alternators to continually fail. The battery is good, the grounds seem fine, and for a while it works ok never exceeding 14 volts. I have an aftermarket sound system with woofers and an amplifier, but I installed a capacitor to protect the electrical system. I also have aftermarket fog lights installed. I did notice that the air conditioner is always working even when the switch is off because the lines int he engine compartment are always frosted over and icy. The only way to turn it off is by removing the fuse. Perhapes that is straining it.
I also noticed oil leaking from somewhere in the engine but I cannot locate it. The valve cover gasket was leaking but I replaced it and it stopped leaking from there but oil is still leaking everywhere. I noticed the alternaot covered in oil each time it failed could that be it?
Find a repair manual for your Nissan Sentra Repair Question.
By Advertisment,
Posted at Thu May 08, 2008 5:39 pm
By Rob2008, Tech level 2
Yes , I believe that is the problem .With Oil getting in the alternator like that. I don't think it would be able to built up enough amps with oil inside it .
this actually happened to me before ., but I was able to just take the alternator apart and clean it .
Fix the oil leak and then your new alternator should last !
-Rob
Posted at Thu May 08, 2008 5:41 pm
So the air conditioner or sound system arent the problem?
Posted at Thu May 08, 2008 5:53 pm
Yes , It's possible the sound system could be the problem ,but in my opinion the alternator wouldn't function right in oil and in time it would just stop charging your vehicle ...The air conditioner ....You would probably have to have a local mechanic take a look at that to know for sure .
-Rob ,
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Popular Question Topics
Alternator
Starter
Exhaust System
Fuel Economy
Rough Idle
Won't Start
Water Pump
Fuel Filter
Battery
Car Alarm
Multi Rib Belt
Catalytic Converter
Head Gasket
Intake Manifold
Motor Oil
Antenna
Air Bag
Fuel Pump
Seat Belts
Heater Core
Air Conditioner
Transmission
CV Axle Joint
Clutch
ABS
Front Brakes
Brake Rotor
Suspension
Oxygen Sensor
Mass Air Flow Sensor
Spark Plugs
Fuel Injector
Check Engine Light
EGR Valve
More Topics...
Popular Manufacturers
ACURA
ASTON MARTIN
AUDI
BMW
BUICK
CADILLAC
CHEVY
CHRYSLER
DODGE
FORD
HONDA
HYUNDAI
ISUZU
JAGUAR
JEEP
LAND ROVER
LINCOLN
MAZDA
MERCEDES BENZ
MERCURY
MITSUBISHI
NISSAN
OLDSMOBILE
PLYMOUTH
PONTIAC
PORSCHE
RENAULT
SAAB
SATURN
SUBARU
SUZUKI
TOYOTA
VOLKSWAGEN
VOLVO
More Manufacturers...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
