Car Repair Advice by Professional Automotive Experts
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1992 Mercury Topaz Alternator
Posted at Sun Nov 01, 2009 11:45 am |
By
mac1149,
Have Donated |
Give Feedback | Votes: 0 |
Electrical problem
1992 Mercury Topaz 6 cyl Front Wheel Drive Automatic
How to you remove the alternator on the 6 cyl topaz I tried to do this but there seems to be no way short of removing the rad to do this? |
Find a
car repair manual for your Mercury Topaz Repair Question.
Posted at Mon Nov 02, 2009 3:43 pm |
By
BMRFIXIT,
Certified 2CarPros Master Technician |
                (8478) Give Feedback | Votes: 85 |
ALTERNATOR
CAUTION:When battery is disconnected, vehicle computer and memory systems may lose memory data. Driveability problems may exist until computer systems have completed a relearn cycle. See COMPUTER RELEARN PROCEDURES article in the GENERAL INFORMATION section before disconnecting battery.
Removal & Installation
Disconnect negative battery cable. Disconnect wiring from alternator. Loosen pivot bolt. Remove adjustment arm bolt. Disengage drive belt from pulley. Remove pivot bolt and alternator. To install, reverse removal procedure.
Find a
Posted at Mon Nov 02, 2009 4:37 pm |
By
mac1149,
Have Donated |
Thanks for the info however 6 cyl engine is mounted sideways and it seems to be impossible to get to the bottom bolt, top bolt and belt was not an issue |
Find a
Posted at Mon Nov 02, 2009 5:49 pm |
By
BMRFIXIT,
Remove alternator upper mount bolt.
Raise vehicle.
Remove right splash shield.
Remove drive belt.
NOTE:DO NOT discharge A/C system.
Unmount A/C compressor and move aside.
Remove alternator pivot bolt.
Remove alternator from bracket |
Find a
Posted at Tue Nov 03, 2009 5:23 pm |
By
mac1149,
Have Donated |
Attempted to do this rad hoses in the way and even if I get the pump off looks like I still may have to remove rad or at least remove the hoses Would you happen to have picture or the required pages from the repair manual |
Find a
Posted at Wed Nov 04, 2009 3:36 am |
By
BMRFIXIT,
I am sorry,
I did research our manuals on line and in shop hard copy
nothing more than
and no clear pictures |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
