Welcome to our question and answer forum. Our
Technicians and members answer over 10,000 free and
donated auto repair questions every month. Asking a
question is free of charge, just sign up to our forum.
However if you elect to donate a small sum we will
guarantee an answer from one of our 2Carpros.com
certified technicians. Due to the nature of car repair
problems it sometimes requires some dialog between our
technicians and you to get your problem solved. 100% of
the donation is awarded to the technicians helping you,
questions with donations are answered as promptly as
possible . If you are unsatisfied with our answer we
will gladly return your donation.
Engine Performance problem
1992 Mercury Marquis V8 Two Wheel Drive Automatic 170000 miles
I have a 92 grand marque and everytime i sit at a light are just sitting still with the car on it cuts off but cranks back up but as long as i have my foot on the gas it stays on help me please
Most likely a bad Idle Air Control Valve. They can go bad and not set a check engine light. This will cause the car to not idle. Also check for vacuum leaks
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more.
