Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair1991 Honda Civic
Auto Repair1989 Lincoln Town Car S...
Auto Repair1995 Mitsubishi Mirage ...
Auto Repair2000 Mazda Protege Maf ...
Auto Repair2000 Honda Odyssey Trac...
Auto Repair1997 Mitsubishi Montero ...
Auto Repair1990 Chevy Lumina Idlin...
Auto Repair More Repair Topics...
Free Car Repair Advice by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1992 Mazda 929 Will not start.
Posted at Wed Nov 18, 2009 9:54 am
By sylvsholl, Have Donated
(9) Give Feedback | Votes: 0
Engine Mechanical problem
1992 Mazda 929 6 cyl Two Wheel Drive Automatic 70000 miles
I have a Madza 929 with 70,000 miles on it. The car had sat for time and was not driven. When I bought the car I replace the time belt first off, then I had to replace two Hydraulic Lash Adjusters in the right side of the motor. After carefully disassembling and labeling each parts I reasemble the head putting all parts back into their place. Line up all the timimg marks. Tried to chank the car it would crank up and cut back off if you tried to crank it again it the car would flood out. I went back into the car to check the timing it seem to be alright I even asked a high school class mate of mind that work as a mechanic for the Madza dealer ship for a number of years to look at it. And he said the car was in time. He suggested that I change the fuel pump relay connector in the relay box. I did that and tried to crank the car agin it crank up cut back off. Other items I chance Battery new, Battery cables in good condition. Distributor Cap, Fuel Filter,Wireset, Spark Plugs all new. Starter, Alternator rebuild. Fuel Filter new,Throttle Sensor new. EGR Valve checked I even preform the flashlight test on the EGR Valve and I could not see the light. I've also replace the water temperature sensor in the intake and the one by the heater inside the car. I've also check the firing order a number time and it is correct according to my alldata computer program. The rotor is also new as well. Need some help bad.
Find a car repair manual for your Mazda 929 Repair Question.
Posted at Wed Nov 18, 2009 5:57 pm
By Service Writer, Certified 2CarPros Master Technician
Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2Reputation: 7321.2 (7321) Give Feedback | Votes: 98
Have you checked compression?
When it sets it may need a few squirts of oil into the cylinders to fill what has drained off.
Posted at Fri Nov 20, 2009 2:17 pm
oK sorry it had take me so long to get back to you. I have checked the ERG valve like you saay using a pump. I could hear and see the it move up and down next I checked the Fuel pump I used a pressure tester from Auto Zone following the what they said to do and I could not get a reading.
Posted at Sat Nov 21, 2009 12:38 am
EGR valve?
Compression test on the cylinders was what I meant.
So you have no fuel pressure?
You then need to access the connector at the pump and see if it is getting power.
I thought the engine was flooding...
Posted at Wed Dec 02, 2009 4:20 am
I found your example of the Mazda Diagnostic connector. Using a jumper connector I connected the TEN & GND. I did not receive any flashes could this be a sign of something wrong with the computer?
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
