Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair2002 Renault Scenic Pro...
Auto Repair1998 Renault Megane Ove...
Auto Repair1998 Mitsubishi Shogun ...
Auto Repair2008 Chevy Malibu Brake...
Auto Repair1995 Chevy S-10 Bubblin...
Auto Repair2000 Honda Accord
Auto Repair1993 Volkswagen Golf En...
Auto Repair More Repair Topics...
Free Car Repair Advice by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1992 Lexus SC 400 Failure of cruise control and speedometer
Posted at Wed Nov 11, 2009 9:02 pm
By mont.auto, Have Donated
(17) Give Feedback | Votes: 0
Electrical problem
1992 Lexus SC 400 V8 Two Wheel Drive Automatic 121000 miles
While driving at highway speeds, cruise control failed along with speedometer. Tachometer still works. Replaced speed sensor at tail end of transmission and rebuild display cluster. Car runs fine save no speedometer and no cruise control. Suggestions?
Find a car repair manual for your Lexus SC 400 Repair Question.
Posted at Thu Nov 12, 2009 8:57 am
By KHLow2008, Certified 2CarPros Technician
Reputation: 5039.5Reputation: 5039.5Reputation: 5039.5Reputation: 5039.5Reputation: 5039.5Reputation: 5039.5Reputation: 5039.5Reputation: 5039.5Reputation: 5039.5Reputation: 5039.5 (5039) Give Feedback | Votes: 68
Hi mont.auto,
Thank you for the donation.
The problem should be with the Vehicle Speed Sensor.
Did you test the pulse from the VSS?
Did you check if the driven gear in trans housing is good?
Posted at Thu Nov 12, 2009 10:40 am
Installed a new speed sensor (eventhough the old one looked OK).
Did not check for pulse from the VSS. Please explain.
Have a good day.
Posted at Sun Nov 15, 2009 6:35 am
Sorry for the delay in replying.
VSS would not show any defet if it is faulty as it is electrically controlled and you need to test the pulse. One simple way is to check if the driving or driven gear is faulty.
Here are the diagnostic procedures for testing.
Speedometer/Vehicle Speed (4-Pulse) Signal Check
1 . Drive vehicle and check odometer operation. If odometer does not operate, trouble shoot odometer. If odometer operates properly, remove instrument cluster with wiring harness still attached. Go to next step.
2 . Turn ignition on. Connect voltmeter between instrument cluster connector terminal No 14, connector A, and ground.
Raise and support vehicle and rotate drive shaft.
3 . Voltage should fluctuate between zero volts to 5 volts (or more) per revolution of drive shaft. If voltage does not exist or does not fluctuate as indicated, go to step 5). If voltage fluctuates, go to next step.
4 . Check wiring harness between instrument cluster and cruise control ECU. If speedometer/vehicle speed (4-pulse) signal and wiring harness are okay, check and replace cruise control ECU. If speedometer/vehicle speed (4-pulse) signal and wiring harness are not okay, trouble shoot instrument cluster or repair wiring harness.
5 . Replace circuit plate. If circuit operation is correct, replace character plate. If circuit operation is still incorrect, replace instrument cluster computer.
© 2008 Mitchell Repair Information Co., LLC.
Posted at Sun Nov 15, 2009 6:34 pm
Thanks for your recent e-mail. As of this writing, we've installed a new speed sensor and the instrument cluster has been rebuilt by others. The symptoms of the problem are that the Odometer, Speedometer and Cruise Control are not working.
Your memo implied that we should pulse the VSS if the Odometer is working as if these items are all arranged in series with the Odometer being first, then the Speedometer and finally the Cruise Control. Is this correct?
Is yes, what is the proper procedure for trouble shooting the Odometer?
Have a good day.
Posted at Mon Nov 16, 2009 10:24 am
Odometer works when the VSS is sending signals so I would suggest you test the VSs signals and skip the odometer first.
One simple way to test is to remove the VSS and connect the wire harness. Get some one to turn the ignition switch ON and watch the speeedometer while you turn the VSS. If needle flickers, most probably the trans driving gear for the VSS is faulty.
Posted at Mon Nov 16, 2009 7:09 pm
OK. So, evidently the drive gear for the VSS is not attached directly to the output shaft (that is, gear teeth haven't been machined into the output shaft) . There is evidently some other power transfer mechanism involved. Yes?
If yes, what is the other mechanism? Generally, how does what powers the input gear of the VSS fail and how is it generally repaired?
Have a good day.
Posted at Fri Nov 20, 2009 6:19 am
Sorry for the delay in replying. I wonder why I am not getting any notification for this post though I have indicated that I should be notified.
The dirve gear is splined and installed onto the output shaft. If the gear is faulty, you would have to remove the end housing to get at it.Repair would depend on the fault.
The gear seldom fails though it can if the splines are damaged.
Did you do the test by turning the VSS?
Here is a diagram for testing the Odometer.
Posted at Fri Nov 20, 2009 11:56 pm
In response, have not tested by turning the VSS yet. Will advise. Have a good day.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
