Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Car Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1996 Dodge Neon Stalls
Auto Repair1997 Audi A6 No Heat Fr...
Auto Repair2001 Mercury Cougar Alt...
Auto Repair2002 Chrysler Pt Cruiser...
Auto Repair1995 Plymouth Voyager W...
Auto Repair1996 Acura Tl Car Radio
Auto Repair1990 Nissan Sentra Engi...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Talk - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1992 Jeep Wrangler Engine cranks, won't start
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Sat Sep 06, 2008 8:20 am
By 92wrangler, Have Donated
Give Feedback | Votes: 0
Electrical problem
1992 Jeep Wrangler 6 cyl Four Wheel Drive Manual 150000 miles
My jeep has a no start condition, engine cranks but no power to the coil and no check engine light. I have checked the fuses, electrical connectors and the ignition switch along with the auto shutdown relay. Any ideas before i spend the big bucks for the ECU?? Thanks
Find a car repair manual for your Jeep Wrangler Repair Question.
Posted at Sat Sep 06, 2008 8:49 am
By merlin2021, Certified 2CarPros Master Technician
Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1Reputation: 633.1 (633) Give Feedback | Votes: 51
ENGINE SENSORS & SWITCHES SENSORS & SWITCHES Camshaft Position Sensor (Synchronization Signal Generator) 1. Use an analog voltmeter. DO NOT remove distributor connector from distributor. Insert voltmeter leads into backside of distributor wiring harness connector to make contact with terminals. Ensure that connector is not damaged when inserting test probes. 2. Insert positive voltmeter lead into synchronization signal output Tan/Yellow wire on Cherokee and Comanche (Gray/Black wire on Wrangler) at distributor wiring harness connector. 3. Insert negative voltmeter lead into ground Black/Blue wire (Brown/Red wire on Wrangler) at distributor wiring harness connector. Set voltmeter to 15-volt DC scale. 4. With distributor cap removed, manually rotate engine until pulse ring enters sync signal generator. Turn ignition switch to ON position. With pulse positioned in the sync generator, reading should be about 5 volts. 5. If no voltage is indicated, check voltmeter leads for good connections If connections are okay and there is still no voltage, check for voltage at Orange supply wire on Cherokee and Comanche (White/Black wire on Wrangler). 6. If no voltage is indicated at supply wire, remove engine controller and check voltage at pin No. 7. Engine controller is located on left side of engine compartment. If there is no voltage at engine controller, see appropriate synchronization sensor/circuit tests in the appropriate TESTS W/CODES article. 7. If voltage is indicated at engine controller pin No. 7, but not at supply wire, check continuity of supply wire between the distributor connector and the engine controller. If no continuity exists, repair wiring harness as necessary. 8. If supply wire is okay, check continuity between sync signal output wire at the distributor connector and pin No. 44 at engine controller. If no continuity exists, repair wiring harness as necessary. 9. If sync signal output wire is okay, check continuity between ground circuit wire at the distributor connector and ground. If no continuity exists, repair wiring harness as necessary. If ground wire is okay, go to next step. 10. While observing voltmeter, crank engine. Voltmeter needle should fluctuate from 0-5 volts while the engine is cranking. This verifies that stator in distributor is operating properly and that a sync (pulse) signal is being generated. If voltmeter does not fluctuate, replace synch sensor stator. Coolant Temperature Sensor 1. Disconnect coolant temperature sensor. Using a DVOM, check the sensor resistance. Resistance should be as specified in the COOLANT TEMP SENSOR & MANIFOLD AIR TEMP SENSOR RESISTANCE table. Replace sensor if necessary. 2. Check continuity between engine controller wiring harness terminal No. 2 and sensor connector terminal. Also check continuity between engine controller wiring harness terminal No. 4 and sensor connector terminal. Repair wiring if an open circuit is indicated. Crankshaft Position Sensor 1. Disconnect crankshaft position sensor. On Cherokee and Comanche, connect ohmmeter across sensor terminal "A" (Orange/Dark Blue wire) and terminal "B" (Black/Light Blue wire). On Wrangler, connect ohmmeter across sensor terminal "A" (Brown/Red wire) and terminal "B" (Red/Green wire). 2. Ohmmeter should read 125-275 ohms with engine hot. Replace sensor if reading is not as specified. Also see appropriate crankshaft position sensor tests in TESTS W/CODES article in this section. Manifold Absolute Pressure (MAP) Sensor 1. Inspect MAP sensor vacuum hose connections at throttle body and sensor. Replace or repair vacuum hose if necessary. 2. Turn ignition on, engine off. Using DVOM, check MAP sensor output voltage. On Cherokee and Comanche, connect DVOM to MAP sensor terminal "B" (Dark Green/Red wire). On Wrangler, connect DVOM to MAP sensor terminal "B" (Red/White wire). 3. Output voltage should be 4-5 volts. Voltage should drop to 1.5-2.1 volts with a hot engine operating in Neutral and at idle speed. Also check for output voltage at engine controller wiring harness terminal No. 1. If voltage is not as specified in step 2), repair wiring harness if necessary. 4. With ignition on, check MAP sensor supply voltage at sensor connector terminal "C" (Violet wire on Cherokee and Comanche or Brown/Yellow wire on Wrangler). Supply voltage should be 4.5-5.5 volts. Also check for supply voltage at engine controller wiring harness terminal No. 6. If supply voltage is not as specified, repair wiring harness if necessary.
Check continuity of MAP sensor ground circuit at sensor connector terminal "A" (Black/Light Blue wire on Cherokee and Comanche or Brown/Red wire on Wrangler) and engine controller wiring harness terminal No. 4. Repair wiring harness if necessary.
Check continuity of MAP sensor ground circuit at engine controller wiring harness terminal No. 4 and engine controller wiring harness terminal No. 11. If ohmmeter indicates an open circuit, go to next step. If ground connection is okay, replace the engine controller.
Check for defective sensor ground connection. Connection is located on right side of engine block, at oil dipstick tube mounting block. Repair connection as necessary. Manifold Air Temperature (MAT) Sensor
Disconnect coolant temperature sensor. Using a DVOM, check the sensor resistance. Resistance should be as specified in the COOLANT TEMP SENSOR & MANIFOLD AIR TEMP SENSOR RESISTANCE table. If resistance is not as specified, replace sensor.
Check resistance between engine controller wiring harness terminal No. 21 and sensor connector terminal. Also check resistance between engine controller wiring harness terminal No. 4 and sensor connector terminal. Repair wiring if resistance is greater than 1 ohm. Oxygen (O2) Sensor (Heating Element)
Disconnect oxygen sensor connector. Using an ohmmeter, check sensor heating element resistance.
On Comanche and Cherokee, connect ohmmeter to Black/Tan and Dark Green/Black sensor wires. On Wrangler, connect ohmmeter to Black and Dark Green/Black sensor wires.
Heating element resistance should be 5-7 ohms. Replace oxygen sensor if ohmmeter reads infinity. Park/Neutral Switch (AW-4 Auto. Trans.)
Disconnect park/neutral switch. Ensure continuity exists between terminals "B" and "C" with transmission in Park or Neutral. See Fig. 1 .
Ensure continuity exists between terminals "A" and "E" with transmission in Reverse. See Fig. 1 . Ensure continuity exists between terminals "A" and "G" with transmission in 3rd gear.
Ensure continuity exists between terminals "A" and "H" with transmission in 1st or 2nd gear. See Fig. 1 . If switch fails continuity tests, replace park/neutral switch.
1: Testing Park/Neutral Switch Continuity (AW-4 Auto. Trans.) NOTE: If terminal No. 4 has a short circuit to 12 volts, correct this condition before replacing engine controller. If necessary, perform appropriate MAP sensor tests in TESTS W/CODES article in this section.Park/Neutral Switch (32RH Auto. Trans.) 1. Disconnect park/neutral switch. Check continuity between switch center terminal and transmission case. Continuity should exist only when transmission is in Park or Neutral. 2. Shift transmission into Reverse. Check continuity between the 2 outside terminals on switch. Continuity should exist only when transmission is in Reverse. Check continuity between each outer terminal and transmission case. 3. Continuity should not exist between either terminal and case while in Reverse. If switch continuity tests are okay, check gearshift adjustment or back-up light circuit. If switch fails continuity tests, replace park/neutral switch. Throttle Position Sensor (TPS) 1. Turn ignition on. Check TPS output voltage at sensor wiring harness center terminal. At idle, output voltage should be greater than 200 millivolts. 2. Gradually open throttle plate. Output voltage should gradually increase as throttle plate is opened. At wide open throttle, output voltage must be less than 4.8 volts.
W/CODES article in this section. NOTE: Also see appropriate throttle position sensor tests in TESTS W/CODES article in this section.
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
