Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Repair Question Archive
Auto Repair Repair Troubleshooting
Auto Repair How to Repair or Service
Auto Repair Car Repair Forum
Auto Repair Auto Repair Manual
Auto Repair How to use Diagnostic Tools
Auto Repair Auto Term Abbreviations
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Popular Site Links
Auto Repair Maintenance Schedule
Auto Repair How Does it Work?
Auto Repair Car Repair Video Series
Auto Repair Car Safety Inspection
Auto Repair Timing Belt Marks
Auto Repair Drive Belt Routing Diagrams
Auto Repair Trouble Code Table
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Smog Test Preparation
Auto Repair Car Replacement Parts
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair1998 Gmc Sierra No Brak...
Auto Repair1997 Ford Escort Weird ...
Auto Repair1996 Honda Accord No Po...
Auto Repair1992 Cadillac Deville R...
Auto Repair1995 Dodge Caravan Shak...
Auto Repair1998 Ford Windstar Powe...
Auto Repair2003 Subaru Outback Thu...
Auto Repair More Repair Topics...
Site Advertising
Car Repair Forum - Ask a Question, Get a FREE Answer.
Log inLog in RegisterRegister ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearchFAQFAQ
 Go Back
1992 Honda Accord VSS
Welcome to our question and answer forum. Our Technicians and members answer over 10,000 free and donated auto repair questions every month. Asking a question is free of charge, just sign up to our forum. However if you elect to donate a small sum we will guarantee an answer from one of our 2Carpros.com certified technicians. Due to the nature of car repair problems it sometimes requires some dialog between our technicians and you to get your problem solved. 100% of the donation is awarded to the technicians helping you, questions with donations are answered as promptly as possible . If you are unsatisfied with our answer we will gladly return your donation.
Posted at Fri Jul 04, 2008 12:40 pm
By drewz, Likes cars!
Give Feedback | Votes: 0
Electrical problem
1992 Honda Accord 4 cyl Two Wheel Drive Automatic 350: miles
Did a motor swap used my auto tranny and wiring harness ,speedo not working : pulled out the vss the drive pin turns when front wheels blocked up, put back together , with a voltmeter checked ground (grreen) good ,checked (yellow wire) 5 v. and put car in gear and checked the (white black srip wire) got 1.02 decreasing to 1.003 when reving the motor in gear and turning tires to 3000rpm roughly, still no speedo????
Find a car repair manual for your Honda Accord Repair Question.
Posted at Sat Jul 05, 2008 4:52 am
By KHLow2008, Moderator
Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7Reputation: 174.7 (175) Give Feedback | Votes: 12
Hi drewz,
Don't start engine. Connect White/black wire to voltmeter and ground.
Disconnect B socket from ECM
Turn ignition switch on.
Put vehicle on stands and slowly rotate front tires, voltage should fluctuate between 0 and 0.5 v. if reading is out, check for shorting of wire, if none, replace VSS.
Posted at Sat Jul 05, 2008 7:01 pm
Not sure were socket B on ECM is. Also do I turn start the engien and put the transmisson in drive. Thanks, Drew
Posted at Sat Jul 05, 2008 7:14 pm
Hi drew,
The B socket is the middle connector plugged into the ECM found under the floor carpet under the passenger side.
No, just turn ignition switch on with trans in N.
Posted at Wed Jul 09, 2008 11:33 am
so i dssconected the middle socket on the ecu jacked up the car turned on the key put tranny in neutral hand rolled the tire white+black 1.07 v yellow still 5 v no fluctuation w/b wire? steady 1.07
Posted at Thu Jul 10, 2008 2:59 am
Hi drewz,
Replace the VSS.
Posted at Fri Jul 25, 2008 12:06 pm
KHLow2008 Posted: Thu Jul 10, 2008 2:59 am Post subject:
Hi drewz,
Replace the VSS.
drewz Posted: Wed Jul 09, 2008 11:33 am Post subject: 92 accord
KHLow2008 Posted: Sat Jul 05, 2008 7:14 pm Post subject:
Hi drew,
drewz Posted: Sat Jul 05, 2008 7:01 pm Post subject: 92 Accord VSS (white black output)
KHLow2008 Posted: Sat Jul 05, 2008 4:52 am Post subject:
Hi drewz,
drewz Posted: Fri Jul 04, 2008 12:40 pm Post subject: 1992 Honda Accord VSS
Electrical problem
Bought a new VSS installed went for drive no speedo, jacked up pass.tire unplugged socket "B"on ecu turned on key put in neutral hand rolled the tire 5v on yellow .41 on white black and increased to.45 when I hand rolled tire ??
Powered by phpBB © 2001,
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Front Brake Pads
Tune Up
Transmission Service
Rear Brake Pads
Rear Brake Shoes
Replace Window Motor
Test Alternator
Test Battery
Replace Air Filter
Check Engine Light
More Service Repairs...
Car Repair Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l Computer Questions l Affiliate Program
  Copyright © 1998 - 2008 2CarPros.com - Professional Mechanics Online
