Logo Automobile Information Add to Favorites  Automobile InformationLogin  Automobile InformationSign Up
Auto Repair
Auto Repair Home
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair How Does it Work
Auto Repair Automobile Safety Inspection
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Car Repair Manuals
Auto Repair Brake Replacement Guides
Auto Repair Tips Car Owners Should Know
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Definitions
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Recent Repair Topics
Auto Repair2003 Dodge Dakota Obd C...
Auto Repair1985 Ford Ranger Draini...
Auto Repair2000 Ford Ranger Four W...
Auto Repair2005 Jeep Liberty Fuel ...
Auto Repair1981 Gmc C1500 Power Wi...
Auto Repair1998 Ford Ranger Transm...
Auto Repair1998 Saturn Sl2
Auto Repair More Repair Topics...
Free Car Repair Advice by Professional Mechanics
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1992 Ford Escort Clutch Replacement
Posted at Sat Jul 04, 2009 12:13 am
By ancientone666, New to the forum
Give Feedback | Votes: 0
Engine Mechanical problem
1992 Ford Escort 4 cyl Front Wheel Drive Manual
Can you please tell me step by step how to replace my clutch with a new one? Or point me in the right direction. Thanks,
Jesse
Find a car repair manual for your Ford Escort Repair Question.
Posted at Sat Jul 04, 2009 3:34 am
By BMRFIXIT, Certified 2CarPros Master Technician
Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9Reputation: 8480.9 (8481) Give Feedback | Votes: 85
Removal
Disconnect negative battery cable. Wedge a wood block (approximately 7" long) between clutch pedal and floor to hold clutch pedal up beyond its normal position. Disconnect clutch cable at release fork.
Remove clutch cable casing from rib on transaxle case. Remove 2 upper transaxle-to-engine bolts. Remove top bolt that secures air management valve bracket to transaxle (if necessary). Raise and support vehicle.
Remove nut and bolt securing lower control arm ball joint to steering knuckle assembly. Discard nut and bolt. Repeat procedure on other side. Using Half-Shaft Remover (D83P-4026-A), pry lower control arm away from knuckle. Repeat procedure on other side.
Fig. 1: Exploded View of FWD Clutch Assembly
Courtesy of FORD MOTOR CO.
CAUTION:To prevent damage to oil seal, use care when using pry bar to remove CV joint.
Using large pry bar, pry left side inboard CV joint assembly from transaxle. Install Transaxle Plugs (T81P-1177-B) to prevent transaxle from draining. Swing steering knuckle and half-shaft outward from transaxle. Secure half-shaft (using wire) in a near level position to prevent damage. Repeat procedure on other side.
Disconnect back-up light switch on top of transaxle. Remove 3 starter bolts and remove starter. Remove shift mechanism-to-shift shaft attaching nut and bolt. Disconnect mechanism from shift shaft. Remove shift mechanism stabilizer bar from transaxle and remove control selector indicator switch arm from shaft. Remove 2 stiffener braces from front of bellhousing and remove speedometer cable. Remove all subframe-to-engine mount bolts, support subframe remove remaining subframe-to-body bolts and lower subframe.
Secure transaxle jack under transaxle and remove 2 bolts attaching rear support mount to floorpan brace. Loosen nut on bottom of front support mount. Remove 3 bolts securing front mount to transaxle. Lower transaxle until it clears rear mount. Support engine block with a screw type jack stand and wood block under oil pan. Remove 4 engine-to-transaxle bolts and lower transaxle from vehicle.
If same pressure plate is to be installed, index mark pressure plate to flywheel. On 1.8L models, install Flywheel Locking Tool (T84P-6375-A). On all models, loosen pressure plate attaching bolts evenly in a crisscross fashion to avoid distorting cover. Remove pressure plate and clutch disc from flywheel. Mount a dial indicator so tip of indicator is against outer clutch disc-to-flywheel contact surface of flywheel. Position pry bar between rear crankshaft flywheel mounting flange and engine block.
Pry crankshaft fully rearward. With crankshaft still fully rearward, rotate crankshaft one complete revolution while noting variation of reading on dial indicator which indicates runout
If runout exceeds specification, use a crisscross sequence to loosen flywheel mounting bolts. Remove flywheel. Repeat runout reading procedure as in step Cool, except place dial indicator tip against crankshaft rear flange face. If crankshaft rear flange is cause of excessive runout, remachine crankshaft rear flange face or replace crankshaft.
Remove pin attaching release bearing to clutch release fork. Remove set bolt attaching clutch release fork to clutch release shaft on transaxle. Slide clutch release shaft assembly out from transaxle.
Installation
Install clutch disc with flatter side toward flywheel as marked. Position clutch disc and align dowel pins of pressure plate onto flywheel. Start pressure plate bolts but do not tighten to flywheel. Install clutch disc aligner into crankshaft pilot bearing.
With clutch aligned, tighten pressure plate bolts in a crisscross sequence until they are just seated. Tighten pressure plate bolts to specification and remove clutch aligner.
Before installation of transaxle, lubricate outside diameter of transaxle front bearing retainer, inside of release bearing, clutch release fork fingers and contact surface of release shaft. Remove flywheel locking tool on 1.8L models.
To complete installation of transaxle, reverse removal procedure. Use new nut and bolt when attaching lower control arm ball joint to steering knuckle. Reinstall subframe and all subframe-to-engine mount bolts. Tighten to 60-86 ft.lbs (81-116 N.m).
Need a tool or a tester CHECK IT @
http://www.2carpros.com/affiliate/uid/bmrfixit_1
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Need parts check it @
http://www.eautopartstore.com/
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
Test Fuses
More Service Repairs...
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Advertise 2Carpros.com
Home l Help l Privacy Policy l User Agreement l About Us l Contact Us l Link to Us l We're Hiring
Copyright © 1999 - 2010 2CarPros.com - Professional Mechanics Online
