Logo Automobile Information Add Site to Favorites
Auto Repair
Auto Repair Home
Auto Repair Ask a Car Repair Question
Auto Repair Car Question Forum
Auto Repair Questions by Manufacturer
Auto Repair Questions by Topic
Auto Repair First Things to Check
Auto Repair How to Repair or Service
Auto Repair Car Repair Manuals
Auto Repair How Does it Work
Auto Repair Car Repair Video Series
Auto Repair Auto Maintenance
Auto Repair Car Sound Problems
Auto Repair Auto Term Abbreviations
Popular Site Links
Auto Repair Automobile Safety Inspection
Auto Repair Brake Replacement Guides
Auto Repair Service Engine Soon Light
Auto Repair Belt Routing Diagrams
Auto Repair Avoid Car Repair Rip Offs
Auto Repair Trouble Code Table
Auto Repair How to use Diagnostic Tools
Auto Repair Smog Test Preparation
Auto Repair Hybrid Car Information
Auto Repair Test Equipment Store
Search Website
Recent Repair Topics
Auto Repair2000 Ford Explorer Noise
Auto Repair1989 Cadillac Deville P...
Auto Repair1987 Ford Laser Fuel
Auto Repair2000 Plymouth Breeze
Auto Repair1989 Chevy Cheyenne 4 W...
Auto Repair2001 Kia Spectra 00 Kia...
Auto Repair1992 Geo Prizm Window R...
Auto Repair More Repair Topics...
Auto Repair Talk - Ask a Question, Get a Free Answer
BackGo Back RegisterRegister Log inLog in Log in to check your private messagesView your posts ProfileProfile Log in to check your private messagesLog in to check your private messages SearchSearch FAQFAQ
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1992 Dodge Shadow Resistance and Ohms Law
Posted at Thu Aug 20, 2009 7:04 pm
By sunshine 03, New to the forum
Give Feedback | Votes: 0
1992 Dodge Shadow
Hi Everyone
I was once told that a common training tool for exposing electricians to resistance; was a large bulb in series with a small bulb. I believe it was on a 12 volt system and the bottom line is; that no matter what - the small bulb was the only one that worked. And another example would be; 6 light bulbs (2 ohms apiece) in series on a 12 volt circuit - resulting in none of the bulbs illuminating properly. Is anyone aware of these exercises and the resistances used in proportion to volts and amps ?
I really appreciate your time and any ideas.
Thanks
Find a car repair manual for your Dodge Shadow Repair Question.
Posted at Thu Aug 20, 2009 8:15 pm
By rasmataz, Certified 2CarPros Master Technician
Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6Reputation: 8488.6 (8489) Give Feedback | Votes: 230
Hmmmm.... Ohms law Its E over IXR
The more resistance in a circuit the less power and vice versus
E
_______
I X R
Ohm's Law defines the relationships between (P) power, (E) voltage, (I) current, and (R) resistance. One ohm is the resistance value through which one volt will maintain a current of one ampere.
( I ) Current is what flows on a wire or conductor like water flowing down a river. Current flows from negative to positive on the surface of a conductor. Current is measured in (A) amperes or amps.
( E ) Voltage is the difference in electrical potential between two points in a circuit. It's the push or pressure behind current flow through a circuit, and is measured in (V) volts.
( R ) Resistance determines how much current will flow through a component. Resistors are used to control voltage and current levels. A very high resistance allows a small amount of current to flow. A very low resistance allows a large amount of current to flow. Resistance is measured in ohms.
( P ) Power is the amount of current times the voltage level at a given point measured in wattage or watts.
Posted at Mon Sep 07, 2009 12:54 am
By caradiodoc, Problem solver!
Reputation: 489.1Reputation: 489.1Reputation: 489.1Reputation: 489.1Reputation: 489.1 (489) Give Feedback | Votes: 8
E = I x R
Reply to topic
Make a small donation! (We will make sure your question will be answered promptly)
Go Back
Forum Home
Find a repair manual for your car - Get instant access to your vehicles drive belt routing, wiring diagrams, trouble code information and other available updates and factory bulletins. Click here to find out more.
Popular Service Repairs
Test Fuses
Replace Front Brake Pads
Check Engine Light
Rear Brake Shoes
Rear Brake Pads
Test Alternator
Replace Air Filter
Test Battery
Tune Up
More Service Repairs...
Car Question by Model
Acura
Alfa Romeo
American Motors
Audi
BMW
Buick
Cadillac
Chevy
Chrysler
Citron
Daewoo
Daihatsu
Dodge
Eagle
Ferrari
Fiat
Ford
Geo
GMC
Honda
Holden
Hummer
Hyundai
Infiniti
International
Isuzu
Jaguar
Jeep
Kia
Land Rover
Lexus
Lincoln
Mazda
Mercedes Benz
MG
Mercury
Mini
Mitsubishi
Nissan
Oldsmobile
Opel
Peugeot
Plymouth
Pontiac
Porsche
Renault
Rolls Royce
Rover
Saab
Saturn
Scion
Seat
Skoda
Subaru
Suzuki
Toyota
Vauxhall
Volkswagen
Volvo
Home l Help l Privacy Policy l User Agreement l About Us l Computer Repair Question l Contact Us l Link to Us l We're Hiring l Affiliate Program
  Copyright © 1999 - 2009 2CarPros.com - Professional Mechanics Online
