Free Car Repair Advice by Professional Mechanics
Welcome to 2CarPros.com free car repair question and answer forum. Our certified technicians answer over 10,000 questions every month. Asking a question is easy, just click the “Ask a Car Repair Question” link in our site menu and join our community. We have short form where you input year/make/model and specific details of your problem. All questions are automatically posted in model specific forums. We will notify you at the email address you signed up with once an answer has been posted. To follow up with our technician, use the “reply to question” button below the answer. If your question is urgent and requires immediate assistance, we have a preferred option; if you elect to donate a small sum of your choice, we will guarantee an answer from one of our certified technicians within 24 hours. If we are not able to help you, we will gladly return your donation.
1992 Dodge Dakota overdrive
Posted at Fri Nov 06, 2009 1:13 pm |
By
ricky601,
Likes to hang around! |
Give Feedback | Votes: 0 |
Transmission problem
1992 Dodge Dakota 6 cyl Two Wheel Drive Automatic 195000 miles
My Dakota will not shift into overdrive. It used to after 5 or 6 miles of driving. Now it won't shift at all. |
Find a
car repair manual for your Dodge Dakota Repair Question.
Posted at Fri Nov 06, 2009 9:51 pm |
By
Jacobandnickolas,
Certified 2CarPros Master Technician |
                               (15758) Give Feedback | Votes: 122 |
Has the check engine light come on? |
Find a
Posted at Sat Nov 07, 2009 8:39 am |
By
ricky601,
No it hasn't. Also at about 55mph it starts missing and backfiring. Whe I ease up off the gas it will run right. But that don't work too good going up hill. |
Find a
Posted at Sat Nov 07, 2009 8:41 pm |
By
Jacobandnickolas,
I need you to check something. Get in the truck and place the key in the ignition. Cycle the key from off to the run position 3 times (do not start engine). On the 3rd time, let the key stay in the run position. THe check engine light will begin to flash codes.
The codes for a 92 are 2 digit numbers. The light will flash then there will be a sligh pause and it will start again to identify the 2nd number of the code. After it finishes the code, there will be a longer pause and it will move on to the next.
Count the flashes to keep track of the codes. Let me know if there are any and what they are if you find any.
I got you beat (but not by much), my 92 has 220K on it and going strong. It has a 5 speed which will outlast the truck. I use it to haul, plow snow, tow a motorcycle trailer... I love it. We'll figure your problem out. Just hang in there.
At this point, something tells me the torque converter isn't locking up to give you OD, but the backfiring and missing has added a new problem.
Let me know about the code. Also, when you get to code 55, that indicates it has finished.
Joe |
Find a
Posted at Mon Nov 09, 2009 2:50 pm |
By
ricky601,
I checked the codes and the only code I get was a 55. I also went ahead and put some plug wires and a fuel filter on it. It's still doing it. Is there anything I can do to the torque converter without pulling it first?
Thanks. I do aprreciate your help. |
Find a
Posted at Mon Nov 09, 2009 5:26 pm |
By
Jacobandnickolas,
I have to say it, but there is nothing you can to do even with it out to repair it. Please take it to a trans mechanic for their opinion before ripping into it. That is my gut feeling, but I am not there.
Let me know what you find.
Joe |
Find a
Make a small donation! (We will make
sure your question will be answered promptly)
Find a repair manual
for your car - Get instant access to your
vehicles drive belt routing, wiring diagrams,
trouble code information and other available
updates and factory bulletins. Click
here to find out more. |
